Project Motor Swap
Started by FJ1200W, February 07, 2020, 03:13:24 PM
PaulG
Quote from: FJ1200W on May 21, 2020, 01:03:20 PM
Mail came early today -
Hylomar came recommended and what is that in front of the can?
More boxes due tomorrow
Well to me it looks like a burette clamp for lab analysis.  :scratch_one-s_head:
1992 FJ1200 ABS
YouTube Channel Paul G
FJ1200W
Quote from: PaulG on May 22, 2020, 10:28:02 PM
Winner winner chicken dinner!
Columbia, Missouri
USA
Quote from: FJ1200W on May 22, 2020, 06:54:23 PM
Quote from: fj1289 on May 22, 2020, 12:55:05 AM
I think you've got enough for that 100 mph in the 1/8th.
My street bike setup was:
1314 engine, street ported head with drop-in mega cycle cams and flat side carbs.
Front end strapped and rear lowered with longer links and an air shifter
Best run was at Bandimere (5,800' elevation):
60'         1.6670
330'       4.4890
1/8        6.8910   @  101.94
1/4       10.7950  @  124.67
I think you'll have plenty of power closer to sea level.
Excellent information, thank you!
What gearing did you go with?
Pretty sure I was 16/42.  May want to try 17/41 or 42.  Sometimes gearing too steep can make it less forgiving and harder to be consistent.
PaulG
Quote from: FJ1200W on May 22, 2020, 11:28:19 PM
As long as it doesn't come in a bucket I'm good with that!  So next question .... what purpose does it serve for the FJ?  RPM gave a hint, but I'm not a member of The Super Secret Guild Of Extraordinary Mechanic Guru Guys & Girls.  Fit that on a T shirt.
1992 FJ1200 ABS
FJ1200W
Quote from: PaulG on May 23, 2020, 08:28:19 PM
The part mounts on a rod and is easily adjustable allowing for a variety of mounting options.
It's used to hold the graduated cylinder (aka Burette or buret) used to measure the combustion chamber volume accurately.
Columbia, Missouri
USA
FJ1200W
Burette finally FINALLY arrived
I almost cried.....
Columbia, Missouri
USA
Maybe try a steady hand and a finely graduated syringe?
FJ1200W
Quote from: fj1289 on June 02, 2020, 08:41:51 PM
I tried but was not pleased with the consistency.
JB Weld might work - that's my Go-2!  :yahoo:
I'll try some shrink tubing to hold it together, then JB's over that.
Crossing my fingers.......
Columbia, Missouri
USA
Quote from: FJ1200W on June 03, 2020, 12:11:35 PM
That's bad luck, you didn't happen to share that old Missourian saying with the company you bought it from did you?
I don't think heat shrink will work in that location. This is one of those applications where cyanoacrylate glues work best, they seem to perform really well on that sort of break. You could then use something like JB to "gusset" the join externally and give some added strength (as long as whatever you use will stick to glass and set hard)
I hear someone facetiously speculated about me owning one. Well, much to his disappointment, I do. :biggrin: (and somewhere, even a stand and a piece of drilled acrylic)
FJ1200W
Finally - I added another layer of JB Weld "Plastic Bonder" which did not mention glass specifically but it stuck like nobodies business.
Then it was wrapped with self-fusing silicone tape from Walmart
https://www.duckbrand.com/products/paint-diy-tapes/drywall-plumbing-repair/black-1-in-x-10-ft-20-mil
Tomorrow it should be good to go - or broken.
Columbia, Missouri
USA
FJ1200W
Also on my last ride, the fork seal started leaking again.
I tried the plastic tool, it worked for a bit, time to just do it right.
Found a complete kit online at a fair price. Bushings, seals, etc.
I'm not a fan of the odor of old fork oil.
Blah!
Columbia, Missouri
USA
FJ1200W
Ordered up a replacement rotary tool.
As soon at it arrives I hope to get back to my project.
I've got to get the compression ratio figured out and then decide to keep it "as is" or ???
E85 sounds promising
Columbia, Missouri
USA
JMR
Surprised there are stock size valves in there....OS intakes with seat boring to .9 of new valve OD makes a big difference. FJ's run hot normally.....getting almost 12:1 CR with the increased bore is kinda of a gamble. Pray for no traffic jams. I have a 1314 FJ with with about 10:75.....watching the oil temp gauge in any type of stop and go is scary.
FJ1200W
Quote from: JMR on March 17, 2021, 08:43:00 AM
When the original builder built this engine, there were not any oversize valves available.
No plans to use this motor in traffic. If so, so a very short distance.
:D
Does anyone remember what compression the old 1314 Wiseco's were?
13.5:1?
Columbia, Missouri
USA
JMR
Quote from: FJ1200W on March 17, 2021, 12:41:44 PM
:D
13.5:1?
When was that.....OS intakes were available over 30 years ago....probably longer with that crap Manley stuff through Orient Express.....I got all Kibblewhite stuff. Original Wiseco 1314 pistons were 10:25 advertised.
