Almost ready to ride
Started by aviationfred, February 03, 2020, 01:59:59 AM
My 90 has sat unused for 2 1/2 years. Installed new exhaust and fixed a headlight/instrument lighting issue. Aired up the tires and the front valve stem core sleeve blew out.... time to remove the tire and install a 90° valve stem.
oldktmdude
   Fred, unless you are fitting a new front tyre, there is no need to remove the tyre to fit a 90* valve. Leave the wheel on the bike and break the bead with a quick grip type clamp, you can then remove the old valve and insert the new valve. Pump the tyre up to required pressure and you are good to go.
   Regards, Pete.   :good2:
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
Sparky84
Quote from: oldktmdude on February 03, 2020, 03:36:09 PM
Yep, Pete did mine
1979 Kawasaki Z1300
1972 Honda CB750/4 K2
I'll be damned....
That is really cool.  Thanks Pete & Alan.... :good:
