Stater chain getting stuck
Started by Greenlander, January 31, 2020, 02:54:18 PM
Quote from: Pat Conlon on January 31, 2020, 09:43:05 PM
Quote from: ELIMINATOR on January 31, 2020, 08:28:12 PM
If the crankcase had enough fuel in it to cause a hydrolock, surely bump starting it wouldn't work?
Correct, if the crankcase is full you're SOL, you're going nowhere, however if just 1 cylinder is full, or partially full, a locked starter can be a symptom.
Consider this a PSA: Check your petcock. If it dribbles, fix it...or you will bend your rod..... :shout:
(where's Klavdy when you need him?)
Hiya mate!
You're getting stronger, eh?
