Another kickstand extension.
Started by MACHV, January 16, 2020, 08:46:55 PM
MACHV
Did the platform shoe mod today, using an old heavy-duty castor wheel.
"I can assure you with no ego, that this is my finest sword. If on your journey, you should encounter God, God will be cut"
How heavy is it?  Will it deploy the stand if you hit a sharp bump?
MACHV
Quote from: FJ_Hooligan on January 19, 2020, 07:16:03 PM
Nah. Weight is pretty negligible. Far less than anything steel I might have hung there.
Some have used Alum, at least one used a hockey puck and I used ABS. It may move under hard suspension use but at that point the bike is much lower and at worse it will kiss the ground before the spring pulls it back up.
