Optional Fork Oils - (Re-hash of an old posting)
Started by Scooterbob, April 29, 2010, 02:53:24 PM
Scooterbob
Is this a viable option??? http://www.fjowners.com/index.php?topic=664.0
It seems too good to be true, compared to the expensive "fork oils".  Sorry if I'm beating the dead horse.  :dash2:
Do not argue with an idiot. They will drag you down to their level and beat you with experience.
-----Bob G.-----
Travis398
Quote from: Scooterbob on April 29, 2010, 02:53:24 PM
i know my owners manual says SAE 10W30 type SE motor oil is the recommended oil (after yamaha fork oil)
so i would guess ATF would be okay, but is that really much cheaper than fork oil?
Scooterbob
Quart of Castrol ATF is about $4.00. Quart of Yamaha Fork Oil is $13.38. So at at 1/3 the price it's an option I'm considering.
-----Bob G.-----
Be aware that there are 3 different viscosities of ATF.
Choose the one you want.
Chrysler ATF+3 = 10W
Dextron 3/Mercon = 15W
Type F = 20W
Scooterbob
Any significant downside to using one of these instead?
-----Bob G.-----
turbocamino
Quote from: Scooterbob on April 29, 2010, 08:32:40 PM
I just installed the chrysler ATF (10wt) along with my new springs....all seems well...ride quality is  normal....I like the fact that ATF has very good cleaning quality's and should keep whatever valves are in the forks clean and working smoothly...i did,at first,notice just a hint of a red haze on my tubes,just above the seals though....seems to have stopped after a few dozen miles. I would recommend it as an acceptable alternative.
89 FJ1200 saphire.blu owned 8-9 years.  By far the most satisfying of them all. Constant tinkering got me the best bike you could ever want.
oldktmdude
 My 1981 Honda Cb900f workshop manual lists ATF as an alternate oil to the recommended fork oil. If my memory serves me correctly, I used to run ATF in my 1980 Kawasaki Z1r as well. A couple years ago I rebuilt a set of forks for a mates Yamaha DT200 and the manual also listed ATF as an alternative. When you think about it, an auto transmission and power steering system has a lot of heat to deal with, so it should work well in a set of forks. Like Arnie said, be sure to pick the correct type of ATF the suit your needs.  Regards, Peter.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
Scooterbob
Looks to be like I'm going to go with an ATF-15W, since I'm a rather "large" guy.  Thanks for all the feedback.
-----Bob G.-----
