'84 FJ1100 resto mod
Started by stou, November 11, 2019, 06:49:11 AM
CutterBill
I'm curious... how did you prep the engine before you painted it?
Bill
Current Stable:
FJ1100
FJ1200 (4)
2015 Super Tenere
2002 Honda Goldwing
stou
It's a very tedious job. I started by blocking every holes. After, I used degreaser and presure wash. Then I used a small air grinder with many size of wire brushes, 3M red scotch brite and some sanding paper. Before painting, I cleaned it with air and then a final wash cleaner that I always use before painting. For the paint, I used an industrial paint that is used for tractors, agricultural machinery, military, etc... This paint is very glossy. So I used matting agent to get a semi gloss finish. It took a hole day to clean and paint it.
stou
Here's a small update. I cleaned and repair thewiring harness, I modified and installed the rear inner fender and battery box. I also installed tht clutch and brake lever. But I have a problem with the brake master cylinder. It work but there's a small leak where is the small lense where we see the level. I have 2 front master cylinder and both are leaking at the same place.
Any idea if it can be repair? Or a good and not too expensive replacement ?
stou
http://www.fjowners.com/index.php?topic=2006.0
Ooops, sorry about that. I see New River Cycle Salvage is still in business, why not give them a call?
stou
Ok, I found them on ebay, Thanks!
Let us know how they fit....I will update our Files
Tuned forks
How do you remember this stuff Pat?
1990 FJ1200-the reacher
1990 FZR 1000-crotch rocket
Years ago, I built the File....
stou
Last week I worked on the carburetors and the heat shield. The carbs was really dirty and the heat shield was really bad. I managed to rebuild the carbs using parts from both sets and rebuild the heat shield with heat protector sheet and heavy duty aluminium foil.
There was waps nest in the top of the carbs
Lot of dirt
The pilot jets was all blocked. One of them jet was stripped and I had to used screw extractor to remove it.
Heat shield rebuild
mtc
Previous Bikes
1979 Yamaha XS1100 best one
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
1978 RD400 Spec II Motor
Live Life Wrong and Perspire
mtc
Previous Bikes
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
Tuned forks
Very impressive job of straightening out that heat shield.
stou
Thanks guys!
mtc, is that FJ on the link you posted is your's? It is very nice!
