'84 FJ1100 resto mod
Started by stou, November 11, 2019, 06:49:11 AM
Pat, he would need to cross drill to connect the two ports and then plug the cross drill to seal it up. One of the existing after market plates are made the same way using 2 O-rings.
Yes, I remember seeing that, kinda complicated, but your way work wouldn't it?
I wonder if 2 small O rings are stronger in resisting the oil pressure vs the slot and 1 larger O ring.
Quote from: Pat Conlon on November 25, 2019, 12:07:21 PM
Yes, it will work, it is only keeping the fork oil from leaking out while it passes through the groove. Not much pressure to hold back. But the smaller O-ring will have less fluid pushing on it. Think pressure per square Inch. A larger piston will push with greater force than a smaller one, it just won't move as far. In the case of a seal, no movement is the goal.
stou
Quote from: Pat Conlon on November 25, 2019, 11:10:49 AM
I don't know what type of pressure is involved with the fork oil, so I suspect it's a good idea going to a O ring design instead of a paper gasket....just a hunch.
Question: If you need to slot the block off plate, how are you going to get a seal with 2 round o rings?
One large O ring like Monkey shows on his plate is the way to go.
That's the beauty of 3D printing. I can design the 2 round holes with the o'ring grooves and a channel in the part to connect the 2 holes. No need to do a cross drill hole, it will be print. I'll do the design later this week and I'll show you.
Cool, I look forward to it!
Pat
Dieselman7.3
Just out of curiosity what do the ports do? You couldn't dead head them?
85 fj1100
89 fj1200 - was for parts now a new project
16 Versys 650 - for off payment riding
Past:
05 ex500
78 Ltd750
stou
I had some spare time and did the changes to my design. Here's what it look like.
Quote from: Dieselman7.3 on November 25, 2019, 04:32:18 PM
This allows the oil to flow and do is work. If the holes are block, it's like the anti-dive is always on and the fork become very hard.
Don't need no stinking cross drilling.....very cool. I bet RPM could sell some of those...
Motofun
Cool.  The only thing I'd recommend is a proper o ring groove.   :good2:
'75 Honda CB400F
'85 Yamaha RZ350
'85 Yamaha FJ1100
'89 Yamaha FJ1200
'09 Yamaha 125 Zuma
'13 Suzuki GSXR 750 (track)
'14 Yamaha FZ-09
'23 Yamaha Tenere 7
stou
I did the exact same groove like the one on the anti-dive part. It is flat but not deep, so the o'ring is very compressed when the part is bolt on. It should work fine.
Dieselman7.3
[quote/]
[/quote]
Thanks. I figured it would have been like non anti dive forks if it was dead headed. But makes sense if the ports are there then they'd still be needed... I don't think my anti dives work or atleast not noticeably
85 fj1100
Past:
05 ex500
78 Ltd750
Quote from: Dieselman7.3 on November 26, 2019, 12:28:47 PM
I don't think my anti dives work or at least not noticeably
It is safe to say, you are not alone....
stou
Here's the printed part. It's a little bit hard to see the chanel on the photo but there is a 6mm hole between the 2 o'ring holes.
Dieselman7.3
Quote from: Pat Conlon on November 26, 2019, 01:05:19 PM
I remember my old 86 not working correctly either lol.  How effective were they back in the day?
85 fj1100
Past:
05 ex500
78 Ltd750
