Bermagui Shed Days December 6&7
Started by oldktmdude, October 13, 2019, 04:13:18 AM
Quote from: oldktmdude on October 17, 2019, 05:01:49 AM
Quote from: ribbert on October 16, 2019, 06:03:22 AM
Phil, if you want to wrench the title away from Bermagui you'd better get busy on eBay and BikeSales. According to the Bureau of Statistics, you'd need 8.9 FJ's to match them and another 0.1 of an FJ to beat them  :biggrin:
Noel, there are 6 Fj's in town, Greg has 2. You also need to take into consideration that 5 of the 6 in town are the best models made, red and white 1100's.
  Regards, Pete. :good2:
  Ps. Are you still an FJ owner Noel? Haven't seen your fine example for quite a while. Not too sure if you haven't crossed totally over to the dark side. (German Harleys)
Haha, I'm not going to re do the maths but 6 bikes only further extends your unassailable lead.
Yes Pete, and I still do 90% of my miles on the FJ and ride it every day. It's just that a 1000km day at speed through the mountains in all weather to your's or Troy's place is the very thing the Kraut bike was made for and excels at and trips like that is really the only time it comes out.
I will be on the FJ next manshed, the other one needs a few things doing to it anyway, so to speak. I came home from Troy's on this road and the only car I saw in first 4-5 hours ran me off the road, it took me over an hour to get it back on the road, I can still smell the clutch. Much of this track is single vehicle width and meeting an oncoming car more often than not requires one of them reversing until a spot they can pass is reached.
What few locals there are will only drive at night when they can see headlights well in advance of the actual oncoming vehicle.
Credit: Stock Photo
I had to remove all the luggage from the bike and shed my cold weather gear to get it onto the road and must have dropped my heated vest controller there somewhere, I won't be going back for it! Coming from this end would have me on the outside most of the time and that would just be suicidal.
It is suggested that not only should a chain saw be carried but sharpening equipment as well, along with shovels and crow bars to move land falls and rocks as turning around is not possible for considerable distances. On my trip there were sections where zig-zagging at walking speed between scattered rocks up to football size was necessary.
It took me until early afternoon to do 230km.
The FJ's much better at this stuff.
Troyskie
I'm in fellas! But I have my work Xmas party on the 6th, so I can only make the Saturday.
Troyskie
Quote from: fj-f3a on October 15, 2019, 08:23:05 AM
I have ordered the six wide fibre discs with one narrow, a new Yamaha clutch spring, SS Clutch Line.
I already have a gasket and a new cover.
Gavin
Gav, follow this method http://www.fjowners.com/index.php?topic=1808.0
Dump the narrow fibre and replace it with a full size. Throw away the retainer spring, you don't need it.
You can do this job with the bike on the side stand.
As Pete suggests, bring a gasket & you won't need it, but if you don't bring one.... :sarcastic:
I've not had an issue with my 11 or  12 since doing the above method. I use one old diaphram spring doubled on a new one.
Troyskie
Quote from: ribbert on October 17, 2019, 09:33:51 AM
https://wickedwalkabout.com/wp-content/uploads/2018/05/Australias-Most-Dangerous-Public-Road-McKillops-Road-Victoria.jpg
That is a huge bummer Noel, you all good?
I have ordered the six wide fibre discs with one narrow...
Gavin
Gav,
If doing the WCD Mod,  you'll need 7.
Tuned forks
If Randy is referring to the adding a clutch disc in place of a steel mod, then I wholeheartedly recommend it.  My clutch was slipping during Kookaloo moments but now it holds solid and that's with just one Yamaha clutch spring.
1990 FJ1200-the reacher
1990 FZR 1000-crotch rocket
Quote from: Tuned forks on October 18, 2019, 07:25:24 PM
Nope,  I would never recommend removing a steel floater in favor of a fiber.
You need 7 if you remove the most inward narrow clutch disc, cushion spring and wear ring.
Tuned forks
Oh yeah, that was it.  Sure worked great!
fj-f3a
Quote from: racerrad8 on October 18, 2019, 07:05:50 PM
Gavin
Gav,
Randy and Troy
Sorry for the confusion.
I have ordered the RPM kit which contains 7 wide and 1 narrow disc so, it appears I have ordered the correct kit.
I mistakenly thought the kit contained 6 wide discs.
Troy, which day are U leaving, Friday?
Gavin
Wings Level
1990 FJ1200, Wet Pale Brown
J17xMT5.5 rear wheel from a 2001 Kawasaki Zx9r
Stainless exhausts
Electronic cruise control
Custom seat
Yamaha R6 Blue Spot Callipers
FJR1300 Master Cylinder
Stainless brake lines
Sparky84
14 days til bike packing time  :yahoo:
Any fires down your way Pete & Alf?
Also hoping there's no fires on the way down that are closing the roads.
1979 Kawasaki Z1300
1972 Honda CB750/4 K2
oldktmdude
   G'day Al, no fires down this way yet although it's very dry down here. We've just got back from a 8 day ride up north, as far as just over the Queensland border and compared to to what we saw, we have it pretty good down here. Hopefully it stays that way. What's happened to the time, its gone so fast!
Looking forward to catching up with everybody.
  Regards, Pete.  :good2: :drinks:
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
Sparky84
Quote from: oldktmdude on November 19, 2019, 06:08:22 PM
Well that's what happens when you go and Retire Pete!
Did you have to change your routes due to the fires?
1979 Kawasaki Z1300
fj-f3a
Alan
Which day will you be leaving and have you a preferred route?
I am hoping to leave Thursday and travel via Tumbarumba.
Trying to get more than two days off at this time of the year, near on impossible.
Gavin
Wings Level
Stainless exhausts
Custom seat
oldktmdude
Quote from: Sparky84 on November 19, 2019, 06:37:50 PM
I haven't retired yet Al, I consider myself as semi-retired. We intended to ride via Waterfall Way down to Grafton but due to fires we had to go through Dorrigo, Bellingen and Glenreagh. We passed through Glenreagh at about 3pm and had to use our headlights to see where we were going until about 15kms from Grafton.
The smoke was incredible and we were bombarded with ash and debris from the fires. Apart from that our ride was not affected too badly. Our timing was pretty good as more and more roads were being closed after we had left. We covered nearly 4,000 kms and traveled on some great roads and saw some awesome and  shocking sights with the drought and recently burnt bushland.
  Regards, Pete.
P.S Gav, if you need any info on the roads to get down here via Tumbarumba let me know.
2009 TDM 900
2004 GasGas Ec300
Sparky84
Quote from: fj-f3a on November 19, 2019, 07:44:31 PM
Alan
Gavin
Sounds like it might be Thursday.
As for route, not northwards  :i_am_so_happy:
1979 Kawasaki Z1300
