Rear wheel finally swapped.
Started by MACHV, October 11, 2019, 08:59:01 AM
FJ12IRL
I just used the rear wheel and sprocket carrier from a Thundercat 600..
So easy to do at home with a grinder and hand tools.
Quote from: FJ12IRL on October 19, 2019, 08:32:50 AM
I was also surprised when people were saying here that the GSXR wheel swap was the simplest !!!!!!
But, with the Thundercat we do only get the 5" rear wheel, rather than the 5.5" and that can be an issue for some people.
Just do the complete Thunder Ace rear end swap, swinger and all....
copper
Quote from: MACHV on October 12, 2019, 12:02:33 PM
It's gotta be a fluke.
Otherwise, why wouldn't either the original aluminum swingarm mount bracket or a new welded one not crack before shearing a steel bolt? Seems a little counter-intuitive, at least, when looking at the meat of the old mount point.
Maybe your right, it is a fluke.
Quote from: MACHV on October 16, 2019, 09:25:23 AM
BS. Suzuki didn't deem it necessary to mount to the swingarm, so now that I see this, I feel better about my solution.
If it was good enough for Suzuki, hell it should be good enough for everyone. Just run it, whats the worst that can happen? Maybe you could die (thats bad :negative:)
Quote from: Millietant on October 19, 2019, 03:09:10 PM
.....I was also surprised when people were saying here that the GSXR wheel swap was the simplest !!!!!!
fj-f3a
I still feel my "Z" shape, Off Set Torque Arm idea will work and be simple to manufacture and implement.
Something like this.
You will need to fabricate and weld some U shaped brackets to the ends of the torque arm for fixing to the existing mounting on top of the swing arm and the caliper.
Use a quality carbon steel for the arm and brackets, not stainless steel.
The gussets will add strength.
Gavin
Wings Level
1990 FJ1200, Wet Pale Brown
J17xMT5.5 rear wheel from a 2001 Kawasaki Zx9r
Stainless exhausts
Electronic cruise control
Custom seat
Yamaha R6 Blue Spot Callipers
FJR1300 Master Cylinder
Stainless brake lines
Quote from: Pat Conlon on October 19, 2019, 05:31:51 PM
Oh yes, defo the ultimate option !!!! (But still not the "simplest" :-) :-))
woodcreekpete
OR:
  Take your original caliper bracket and cut it where the line is in the picture. Finished length should be 20mm shorter than original. Bevel out the areas that'll get welded. Clamp it or bolt it to a stiff piece of steel to keep the inner machined faces parallel. This ensures that the caliper will align properly with the rotor. Get someone qualified to weld the shit out of it. Make a new torque arm out of 1/4" steel or aluminum. Might need a bit of offset to line up properly.
That's it - simple, uses original caliper and hose. Cheap - cost me $25 Cdn. I've done 4 or 5 this way with no problems.
What's so hard about a couple spacers? I used washers. The GSXR requires no machining, welding, or fabrication of any kind. Just use the GSXR torque arm and attach it to a new bolt at the backside of the foot peg. Ride, repeat.
MACHV
Bracket installed. Bolt stress distributed.
Using the scrap on hand, I first made a cardboard model from the box my chain came in, to establish shape and clearance. Went from there. Had a strengthening wall welded (for free) where I wanted. Now the bolt has two sheer planes because it spans a bridge instead of having only one attach point. I refused to take the ass end apart right after putting it all back together and cleaning everything. Plus I was not interested in drilling or welding on the swingarm.
"I can assure you with no ego, that this is my finest sword. If on your journey, you should encounter God, God will be cut"
MACHV
Tuned forks
Looks very sturdy.  Someone mentioned once that having the bolt in double shear really increases the strength of the connection.
1990 FJ1200-the reacher
1990 FZR 1000-crotch rocket
MACHV
Quote from: Tuned forks on October 24, 2019, 07:24:39 PM
Well it made sense, then I studied and confirmed. The former method basically gave the torque arm a whole inch of leverage from where the bolt comes through the frame. Maybe not all the bolts on all the bikes are breaking but, I wasn't going to risk it. Never would have guessed that the above avg bolt might not be enough so...
Thanks to everyone for the input!
