FJR brake light switch
Started by JPaganel, August 03, 2019, 11:08:54 PM
JPaganel
So, I found this curious little problem - my brake light stays on, until I brake. And then it goes out.
The bike has an FJR brake master, and it turns out the switch works in reverse of the original - it's open when released (brake lever pulled), and closed when pressed (brake lever released).
This is not a defective switch - I opened it, and it's designed that way. It's a two-prong switch, so there is no way to connect it wrong.
Is there a switch that will work properly and mount to the FJR cylinder?  Different year FJR, maybe? I had an FJR cylinder on my previous FJ and did not have this problem.
I did a search on the forum, but didn't come up with a definitive answer.
1993 FJ1200 ABS
1984 FJ600, up on blocks
I don't want a pickle
Does the master switch connection have 3 pins or 2?
JPaganel
Quote from: FJmonkey on August 03, 2019, 11:19:36 PM
2.
I think Randy has it.
1993 FJ1200 ABS
JPaganel
Or, actually, doesn't have it, if the website is to be believed.
Randy, are you really out of stock on those?
1993 FJ1200 ABS
Quote from: JPaganel on August 03, 2019, 11:36:28 PM
I really don't know, I'm at home. I did not notice that when I posted the link. I'll have to look Monday morning.  They are from a vendor fairly local and usually can have it in hand the next day.
Stand by...
It sold on the 31st and not sure if Robert ordered a replacement before the end of the week.
I will find out tomorrow morning what the status is.
RPM - Robert
Yes we are out. They are on order and we should have a few more tomorrow or Wednesday.
I bypassed my front brake switch and just use the foot brake to light up the brake light. It's more fun that way at rallies when I'm leading the pack.  :biggrin:
