Idle issues + poor responsiveness
Started by ArmArak, July 07, 2019, 12:35:03 AM
ArmArak
Hi Guys,
I have been having problems with my stock 1986 fj1200. It starts; however, idles low at around 1000 rpm. When the choke is pulled revving takes it up to around 3000 and stays there, pushing the choke in brings it back to 1000. Here when throttle is applied fast the bike doesn't climb in rpm, sputters and stalls. This doesn't happen if the throttle is applied very gradually. https://www.youtube.com/watch?v=5u8BnNQO25I&feature=youtu.be link to a video showing problem.
Thanks
Clean your carbs, in like, don't just spray some cleaner down the throat or pour some cleaner in your fuel tank, no, no, take the carbs off the bike and take them apart and clean them correctly. The idle circuit, the pilot jets and the jet nozzles could be clogged, the choke fuel pick up clogged, and the carb slides could be gummed up.
http://www.fjowners.com/index.php?topic=655.0
Don't leave fuel containing ethanol in your carbs.
Spend $24 and buy this kit from RPM: http://rpmracingca.com/proddetail.asp?prod=carbkit
It's a great value. You need fresh O rings anyway, the new ss allen head screws (replacing the butter soft oem JIS screws)  are the frosting on the cake.
If you can't or don't want to do the carb cleaning job yourself and you have no one local you trust, take your carbs off, drain the gas out, let them throughly dry for a day or two, box them up and send them to Robert @RPM.
He will get the job done right.
BTW there is nothing wrong with a 1,000 rpm idle speed.
Pat
As Pat says...1000 RPM at idle once fully warmed up is fine. The photo is from my Haynes manual.
I had a similar issue with carbs that sat for a few months. The culprit ended up being the fuel inlet screens flunked up
ArmArak
Thank you guys for the tips. The bike is literally twice my age and I don't have the know-how or the place to work on it myself. Can anyone recommend someone local to the Los Angeles area to help me out and give me the opportunity to learn more?
Thanks
Armen
ryanschoebel
It seems a daunting task, but honestly, these bikes are amazingly easy to work on. While I'm sure there are a lot of members willing to help you out and show you, the best way to learn is to honestly just watch a few videos, get a Haynes/Clymer manual, and just open the damn thing up. you'll be surprised at how much you are able to accomplish. I am just a few years older than you, and within a year of owning an FJ, I was comfortable enough to drop the engine out of frame, among many other things. Start small, do research, and ask questions!
1985 FJ1100-- Atlas (SOLD)
1984 FJ1100-- Storm
Tuned forks
+1 on Pat's advice to send the carbs to Robert at RPM.  We have nothing to gain financially by making this recommendation but many or most of us active on this forum have benefitted from Robert's carburetor work.  If you can't afford it, then ask on this forum how to rebuild them yourself but RPM's work is top notch.  Your engine will run sooo much smoother.  You could also caravan up to Oakdale this Oct for the RPM Fall Rally with the other SoCal members.  Look in the Rally section for further information on that event.  There are at least a few members that come up from SoCal, Pat being one of them.
+1 also on the 1000 rpm idle speed although since Robert's work my engine comfortably idles about 750 rpm.
1990 FJ1200-the reacher
1990 FZR 1000-crotch rocket
Armen, Monkey Mark is in your neighborhood...stand by and he will chime in.
What I have noticed is that many motorcycle shops no longer work on carbs. It seems like the young service techs are not trained on the intricacies of a Constant Velocity Mikuni Carb.
For folks who do not wish to fuss with carbs, we are fortunate to have RPM to send our carbs to.
Meantime: Don't store your bike with E10 crap fuel in the tank and carbs.
https://www.samscycle.net/Storage-warning-local-gas.html
Tuned forks
Quote from: Pat Conlon on July 07, 2019, 12:19:11 PM
Hmmm, to easily do this on the fuel pump models, we would have to add an electrical switch to the fuel pump circuit.  Not a biggee and as a matter of fact I did it for the FZR.  Perhaps SF's cool weather has helped me not have the problem on the FJ but I suppose a three way switch is a good idea.
Joe, did you want this post here? ^^^
If not, let me know where you want it and I'll move it for you...
Tuned forks
Pat I was making the point, regarding your link, that to drain the fuel from the latter fuel pump FJ's would require turning off the pump and running the engine until the carbs are dry.  On my bike, I can't reach the petcock without raising the fuel tank up.
Gotcha...
Although, turning off the gas and running the engine until it stalls will not get *all* the fuel out of the fuel bowls (just down to the level of the pilot jets) Whatever is left will turn into a green jelly.
RPM - Robert
Quote from: Pat Conlon on July 07, 2019, 01:37:43 PM
And Pat has first hand experience with the green carbs. :Facepalm:
These were his carbs following the winter 2012 storage.
Yea, I remember that...
E10 came out in Calif. gas in 2010, so that looks about right for 2012....we were still learning....
I hear if you run a tank of 100LL through the bike before storing it, that these sort of problems are well reduced.
