Gixxer rear wheel/caliper
Started by scotiafj, June 23, 2019, 06:13:37 PM
I welded the tab on with the torque arm originally. Monkeys solution is  way to do it without the ability to weld. I then converted both of my bikes to the gsxr600 caliper brackets. With the bilt in torque arm. That slides in a channel welded inside the swing arm.
Quote from: ZOA NOM on June 26, 2019, 07:29:07 AM
That's clean. I like it.
That's why I converted to the 600 caliper brackets.  Besides. The gsxr forum said that the 600 wheel is the lightest. Probably because of the bracket and the sprocket has 1 less bolt. You know less in unspung and reciprocating weight.
scotiafj
Well ditched the gixxer underslung caliper n replaced it with one from a gsx600f ,I flipped the gixxer caliper bracket to the top n fitted the 600f to it ..jus need to bleed it up now an go for a blast
