Spring time maintenance
Started by Maicojoe, May 27, 2019, 02:30:38 PM
Maicojoe
Tuned forks
1990 FJ1200-the reacher
1990 FZR 1000-crotch rocket
Maicojoe
Clean the carbs, oil and filter change, new battery, adjust and lube the chain, check valve lash, a good scrub and polish......, fresh gas and gas filter, just your normal old bike stuff.
Motofun
That's one sweet looking '85!  Other than the front calipers it doesn't look like you've contracted moditis..... :good2:
'75 Honda CB400F
'85 Yamaha RZ350
'85 Yamaha FJ1100
'89 Yamaha FJ1200
'09 Yamaha 125 Zuma
'13 Suzuki GSXR 750 (track)
'14 Yamaha FZ-09
'23 Yamaha Tenere 7
Quote from: Motofun on May 28, 2019, 05:37:17 AM
You've missed the gorgeous wheels then  :biggrin:
Motofun
Si I did!  I was blinded by the light. :shout:
'75 Honda CB400F
'85 Yamaha RZ350
'85 Yamaha FJ1100
'89 Yamaha FJ1200
'09 Yamaha 125 Zuma
'14 Yamaha FZ-09
'23 Yamaha Tenere 7
Maicojoe
Kinda funny, as it's one of most heavily modified FJ bikes you will find....
1315cc engine
Head is ported by Vance & Hines with oversized valves
Cams
Falicon rods, crank, clutch basket
R&D did the transmission, 2nd gear, shift forks etc
44mm flatslides
Supertrap exhaust
Performance Machine 17" wheels
Performance Machine brakes
Works Performance shock
Forks rebuilt with Progressive springs
Dyna ignition
Dynoed 167 HP to the wheel
Maicojoe
Quote from: Maicojoe on May 27, 2019, 02:30:38 PM
Just a little needed PM
All finished.... time to do some riding and racing...
