Kiehin race carb throttle return springs
Started by CanDman, May 21, 2019, 12:17:04 AM
Flynt
Quote from: JMR on May 23, 2019, 06:58:14 AM
turning the hex head under the carb top controls up or down movement of the slide. Raising the slide (turning the hex clockwise) decreases vacuum...lowering it (turning counterclockwise) increases vacuum. The center slotted screw locks down the hex head adjustment nut
That's right...  been so long I forgot how I did it.  Anyway, the adjustment is possible using vacuum port between carbs and head...
JMR
Quote from: Flynt on May 23, 2019, 08:46:19 AM
So I'm not the only guy that experiences that phenomenon.....I feel better now. :biggrin:
