1986 yamaha fj oil leak
Started by Starquest, May 09, 2019, 06:37:11 PM
Starquest
 Hi. I'm new to this site but I'm reading this forum for a few months. I have an oil leak on the left side of the engine. Yesterday I took the alternator off and the starter.The bottom of alternator was cover with oil and the left side of the pan. I found out that the seal started to disintegrating and the o-ring I think was the wrong one.It was a blue and 2.4 mm. The bike was running fine but I'm going to change the alternator o-ring,seal,starter o-ring,clutch slave seal,shift lever seal,neutral switch o-ring,for the piece of mind. I found a company in Europe that sells the o-ring for the 1986.I'll post the results. Thanks again.
Tuned forks
Go here instead.  Two great guys at RPM and they support this forum.
http://rpmracingca.com/products.asp?filter=seal
1990 FJ1200-the reacher
1990 FZR 1000-crotch rocket
Starquest
Yes. Thank you. I ordered a few parts from them.
Starquest
I'm buying most of the parts from R.P.M but this alternator o-ring,nobody has it. Yamaha discontinued this part.
