Timing chain
Started by vettman, May 08, 2019, 02:38:54 PM
vettman
93000 miles re shimmed valve's should i replace oem chain tensioner 1986 fj1200 still runs pretty good,but cam chain is a little lose ? what do yall think. vettman
Nope, check it for Abby normal wear, if good, properly reset it, use a new oem gasket and call it a day.
(Name that movie)
Quote from: Pat Conlon on May 08, 2019, 04:45:21 PM
(Name that movie)
Abby Normal would be Young Frankenstein...
RPM - Robert
Remove the center bolt/springs and THEN remove the tensioner (Failing to do this will fully extend the tensioner and give you a false check) . Be careful not to catch the tip when removing it from the engine. You can then see how far it is extended and if the tip is worn. If it is fully extended it would need a new cam chain, as the chain would be stretched further than any I have seen. If the tip is worn replace the tensioner. If neither of those is the case replace the tensioner gasket and re install.
To install the tensioner compress the plunger all the way, install the tensioner into the block with the locking paw down. Once installed in the block, install the springs & center bolt and tighten. Installation complete.
Quote from: FJmonkey on May 08, 2019, 05:03:13 PM
"It's pronounced Fraankensteen."
Wasn't your hump on the other side?
Listen to me very closely......PUT THE CANDLE BACK.....
So many classic lines in that movie....
moparman70
SWEET Misery of Life and now I have found you..........
Flynt
Quote from: moparman70 on May 12, 2019, 04:42:52 PM
That's "Mystery of life..."
Ovaltine anyone?
