Highway Pegs
Started by ryanschoebel, April 19, 2019, 08:01:15 PM
ryanschoebel
Hey all, I have a set of Renntec bars coming in next week. I want to mount highway pegs to them, but I cant seem to find the way that others have done it. Is it a bad idea to drill a hole through the bars to mount them, or should i really only consider pegs that grip around the bar?
I do what to do some auxiliary lights in the future, so that's a thought as well?
Thanks,
Ryan
1985 FJ1100-- Atlas (SOLD)
1984 FJ1100-- Storm
Tuned forks
Yeah you got long legs Ryan.  Do you get leg cramps on the long trips?
1990 FJ1200-the reacher
1990 FZR 1000-crotch rocket
ryanschoebel
Quote from: Tuned forks on April 19, 2019, 09:25:43 PM
Like crazy Joe. The first few hundred miles are okay, but after that, my hips start crampings, and then everything else follows.
1984 FJ1100-- Storm
I welded plates in the triangle in the front of the bars  not a very good picture but I think you can tell where. Used Fj passenger pegs.
Tuned forks
Nice work GK.
Ryan, all my tall friends ride HD baggers with forward controls.  Kinda says something huh?  If I faintly recall, I think Pat used the Buell foot pegs along with other member(s).  Hopefully Pat will chime in too.
Yep, as Joe said, I use the Buell pegs which are about 1.5"  lower than the oem pegs.
You would think 1.5" would not be of any help, but it's amazing what a difference it makes.
I use a set of Buell Ulysses lowered foot pegs, ( the Ulysses version is wider and more similar to the OEM pegs ). As Pat mentions, the inch and a half of lowered pegs really does make a difference.
Something else that I have found that makes a difference in Long distance comfort. Do not use a Corbin seat. Put the OEM seat on and add an Air Hawk seat cushion. Like the foot pegs but in reverse. The OEM seat is taller than a Corbin, plus you get an additional 1/2 to 1 inch of added seat height with the Air Hawk.
ryanschoebel
Hey all, here is what I ended up doing, for now. I disnt want to weld them permanently, and i wanted to use the FJ passenger pegs so that they match. I got a pair from another member here in Phoenix (thanks Mike!), and bough some HD bar clamps. May change it, have to see how they work out.
1984 FJ1100-- Storm
Tuned forks
That looks great Ryan, kudos laddie!  How do you like that cream puff?
ryanschoebel
Quote from: Pat Conlon on April 28, 2019, 10:28:12 PM
I'm enjoying it quite a bit! There are a few things to sort, IE 2nd gear, front forks, battery and charging, ect, but man, do I sure look a helluva lot better riding down the road! I can actually justify buying things that I couldn't before because the bike is mostly where I want, cosmetically.
1984 FJ1100-- Storm
Ryan, I did exactly what you have done with the highway pegs, but quickly removed them after convincing myself that in a drop they'd likely twist round and punch a hole through the engine, there by negating the whole idea of protection bars.
As for seats, I like the Corbin, but Fred's airhawk probably does a great, if not greater job. I even thought about one of those purple cushion things. Anybody tried one? I suspect they are much like an airhawk......maybe.
Eat fish to cure your aching hips.
For those that don't have renntec bars. I made highway pegs. Using Fj engine mount plates trimmed up turned around and I believe swapped sides they have the perfect angle built in. I think I did a write up. But was a long time ago. And I don't know how to bring a link here. I have a bunch of pictures in my images on the forum. I haven't been able to bring pic's to a post from the images for a while. but I'll give it a shot.http://
Got one to work. Don't know how to fix the other
