Twisted Buckets
Started by Miker, April 12, 2019, 10:57:54 PM
Miker
I just checked the valve lash on my '85.  I noticed a few of the exhaust shim buckets are positioned to where the little notch is inaccessible, so I can't pop the shim out with a flat head screwdriver.  I bought the bike a year ago and this is the first time I checked the valves.  Luckily (for now), I don't need to change those shims.  Rather not have to disassemble everything just to turn those buckets.  Does anyone know of another way to get the shim out of a bucket without access to the bucket notch?  Does anyone think the buckets somehow turned over time due to vibration or were they just installed improperly?
2003 ZX-12R
The bucket will rotate freely before compression.
This will allow access to the slots.
Randy -RPM
Miker
 Thanks very much Fred and Randy!  Great info as usual.
2003 ZX-12R
Miker
Quote from: racerrad8 on April 12, 2019, 11:26:50 PM
Randy -RPM
Hi Randy
I just went back in to try that, but my buckets won't spin.
2003 ZX-12R
Make sure the cam lobe is pointing up to spin that valve. If it still wont spin then you have a problem. Like a valve that is way too tight.
Miker
Quote from: FJmonkey on May 03, 2019, 11:09:36 PM
Thanks. Yup lobe is up. I'm using the valve tool. The buckets definitely move when the engine is in use as they've moved from the position where I last checked them. I just can't move them freely.
2003 ZX-12R
Quote from: Miker on May 04, 2019, 10:45:09 PM
I'm using the valve tool. I just can't move them freely.
I am not sure if you are using the FJ valve tool and then trying to turn the buckets. Turn the cam lobes up, spin the buckets, then put the valve tool in.
Forgive me if you have already done this.  :flag_of_truce:
The bucket will only turn when there is no load on it.  Love pointing away and no tool
If there is pressure,  it is difficult to impossible to turn.
Miker
Quote from: racerrad8 on May 05, 2019, 09:45:47 AM
Gotcha!  I'll try that. Thanks Fred and Randy
2003 ZX-12R
