pucks or crash bars?
Started by mtc, April 03, 2019, 02:27:32 PM
mtc
Quote from: Hersey289 on April 20, 2019, 07:16:45 PM
They will fit fine. Just start all the bolts so all are loose , then start evenly tightening all of them. The rear plate section that you are concerned with will conform/bend slightly to fitup to the frame. That is my experience with installing them on my '85.
Hope this helps,
Rob
the chrome plate i took off has a pipe in that area, it is protruding 1 inch out with the crash bar protrusion,  i can crank bolts down, but my looking at it it's gong to have to bend a lot to fit
Previous Bikes
1979 Yamaha XS1100 best one
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
1978 RD400 Spec II Motor
Live Life Wrong and Perspire
Hersey289
I would suggest then that you tighten the rear bolt more than the front bolts to get better alignment onto the bung on the frame.
Rob
Hersey289
Quote from: Hersey289 on April 20, 2019, 07:44:50 PM
Rob
Sorry, clarification: with rentec bar installed with all bolts loose, bias the rear bolt so that the rentec bar lines up better with the protruding pipe (bung). Once you have this alignment, then continue to evenly tighten all bolts to draw the bar into the frame..
mtc
Quote from: Hersey289 on April 20, 2019, 07:55:12 PM
Rob
Randy told me some of them need spacers, which i am not digging bc it will stick out for no good reason
thank you, but there is a huge gap between the rear strap and the foot peg bracket, it's going to take a lot to bend it to make it flush, as you can see in the picture
maybe someone can show me a picture of my problem solved or even with a spacer?
Previous Bikes
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
copper
I did not want to bend the back brackets. when i asked randy about he recommended installing a spacer in the hole for the rear bolt. i went down to the heradward store and got a steel bushing like this. i cant remeber because it has been a few years, but I think the 3/4 was a little to long and the tube wasnt touching the frame. i think i ended up with a 5/8
https://www.google.com/imgres?imgurl=https%3A%2F%2Fimages-na.ssl-images-amazon.com%2Fimages%2FI%2F61ORWl6opFL._SX425_.jpg&imgrefurl=https%3A%2F%2Fwww.amazon.com%2FHillman-Group-943075-Chrome-Spacers%2Fdp%2FB00O3GTPXA&docid=rFNVL7XXGgZXrM&tbnid=Lp1UNlCj7UjGQM%3A&vet=10ahUKEwigt4rx_d_hAhUmsFQKHQ9-ArgQMwiXASgDMAM..i&w=425&h=378&bih=1041&biw=2133&q=hillman%205%2F16%20steel%20spacer&ved=0ahUKEwigt4rx_d_hAhUmsFQKHQ9-ArgQMwiXASgDMAM&iact=mrc&uact=8
you said randy sent pictures of it what did he say spacers or no spacer?
mtc
Quote from: copper on April 20, 2019, 08:04:18 PM
does that tube have to touch the frame? wouldn't it chafe and make noise when riding? thanks for the link, will i need now bolt too now?
he showed me pics of no spacer, looks good, but i guess i am one of those unfortunate ones, if i can see how a spacer in one looks maybe i won't be so bummed
Previous Bikes
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
Sparky84
Quote from: mtc on April 20, 2019, 07:00:18 PM
i need help , i bought them but they don't sit flush were it butts up against the frame in the back, i am thinking the flexing is going to chafe the bars and the frames
has anyone had this problem? and it appears it needs a spacer, and it going to end up sticking  out a lot, it doesn't seem right to me.....please assist
Randy sent me pictures of them mounted, anyone can send me a picture of what it should look like?
the read stand-off is too large and it's pushing the bar too far out, i think :dash1:
I thought that the renntec bar would have fitted into the hole in the frame!
But looks like it doesn't, so how do you stop the rub rash on the alloy underneath?
1979 Kawasaki Z1300
1972 Honda CB750/4 K2
mtc
Quote from: Sparky84 on April 20, 2019, 08:40:05 PM
i haven't the foggiest idea, looks like a bad design, it should fit in or out but nto be the same diameter as the round tube
Previous Bikes
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
Quote from: mtc on April 20, 2019, 08:51:41 PM
Mason,
I'm sorry to hear you are not happy with them. Please box them back up  and I'll send a call tag on monday to pick them up.
There is nothing wrong with the design,  they have been made the same way since I became a Renntec  dealer almost ten years ago. I have sold hundreds of them and have never had any complaints about the design.  Some people have used washers,  others use them as Rob has and others have used spacers like I told you in the email earlier today.
The tube is designed to sit flush against the frame to offer support in the event the bike goes down.  If they fit inside the frame,  the flat plate would not be able to support the weight.
I will call Monday to confirm they are ready to be picked up before completing the call tag.
And to answer your statement in  your email,  no you did not receive the late model bars,  they will not come close to lining up the holes. You received the correct bars,  but if you are not happy,  I'll get them sent back and return for money.
Randy  - RPM
mtc
Quote from: racerrad8 on April 20, 2019, 09:46:16 PM
Mason,
Randy  - RPM
I am not that great of a mechanic, when i started to install them, they looked like they don't fit and i got concerned and yes you sent me pictures of them fitting without spacers that is nice,
but to see ones with spacers would help a mechanically challenged dude like me.
and with explanations about getting spacers, but i still could not picture still how to do it, until about now, i might have heard vaguely they were included, but it didn't mean anything to me until i had the unit in my hand.
i don't understand why some need spacers and some not.
only now i understand since you  explained the 2 tubes have to meet to support the bike in a crash, now it make sense, i had not idea, no one explained it to me until now
so they have to meet flush? and will they chafe and make noise?
I had no idea they could have been chasing parts, call me lazy really lazy
I am going to look at it again in the next few days time permitting, and let you know, I already trashed the box so that is gone
I may stick a piece of wood in there to fill the gap, may have to measure the gap
Previous Bikes
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
Sparky84
Randy  - RPM
Now I can understand why they wouldn't go inside
1979 Kawasaki Z1300
I dug back into the corner of the shop to my 86 so I could snap a couple of photos. There is a spacer in there that fills the void/recessed hole on the 86 foot peg bracket. I got a spacer length the allowed the tube to butt against the frame and preload the flat bracket a little bit. There is zero movement, squeaking or any other issue.
The reason some require and other don't is the foot peg bracket itself. Some use recessed holes and others have factory rubber bushings installed.
Hopefully, this will ease the concerns.
Man, all of my bikes are dirty...
mtc
Quote from: racerrad8 on April 22, 2019, 12:19:13 PM
I dug back into the corner of the shop my 86 so I can snap a couple of photos. There is a spacer in there that fills the void/recessed hole on the 86 foot peg bracket. I got a spacer length the allowed the tube to butt against the frame and preload the flat bracket a little bit. There is zero movement, squeaking or any other issue.
,when i tried to fit it by myself at first , it did not, it's wrong ....so wrong year, raced in my mind
when you sent the the first pics, the first thing that came to mind is oh no, mine don't look like that at all
then,
i told myself no way am i gonna mickey mouse my bike
so with this recent picture, should did that to begin with.... all is good
ok i put a  coupla nuts in there and it works fine, i can actually pull on the bars to to align the holes
and screw it on there with the allen wrench and it's thight
i think it's better than pucks
btw, the fork brace i can feel the difference.....
thanks
on to the next pressing matter
Previous Bikes
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
mtc
Quote from: mtc on April 22, 2019, 04:59:39 PM
then,
thanks
they look cool on there
but
question, does it have to match the pipe, cause, mine is not perfectly aligned, it guess it don't matter much until a crash
Previous Bikes
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
Quote from: mtc on May 05, 2019, 11:47:40 PM
...question, does it have to match the pipe, cause, mine is not perfectly aligned, it guess it don't matter much until a crash
That is the manufacturing tolerance on both the motorcycle and then engine bars. Not all of them line up exactly.
BTW, were is the wiper seal for your fork?
