New Wheel
Started by roverfj1200, February 19, 2019, 12:48:54 AM
roverfj1200
So the YZF600r wheel arrived today. I laid it out with a spare swingarm and all checks out from what I was told. 8mm off each side with the FJ stock sprocket on backward and stock caliper. Will slot straight in. Will fit it up with a 170/60-17. Anyone know if the earlier Aluminium swingarm will fit the later frames?
1988 FJ1200
Richard.
Quote from: roverfj1200 on February 19, 2019, 12:48:54 AM
.......Anyone know if the earlier Aluminium swingarm will fit the later frames?
To replace the steel swinger on the 4th gen. '91-95 FJ's with an aluminum swinger, you need the 3rd gen. '89-90 FJ swinger which uses the same dog bone style shock linkage. Plug and play.
The early 1st or 2nd gen FJ aluminum swingers ('84-87) will not work on the later FJ's  because the shock linkage is different.
roverfj1200
Quote from: Pat Conlon on February 19, 2019, 01:40:23 AM
Thanks Pat but the swingarm I have is a 88....... would think this the same as your 89 Will just have to try it....
1988 FJ1200
Richard.
........... Will fit it up with a 170/60-17
C'mon Richard, you can fit a 180 on there no worries  :biggrin:
roverfj1200
Quote from: ribbert on February 19, 2019, 04:12:37 AM
Run 180s on the GSXR 5.5" for sometime then fitted a 170 and the difference for the good was amazing
1988 FJ1200
Richard.
Quote from: roverfj1200 on February 19, 2019, 04:16:18 AM
That's very interesting Fred, what form did this improvement take?
roverfj1200
Quote from: ribbert on February 19, 2019, 04:48:34 AM
The bike turned in better and was more sure in the corners
1988 FJ1200
Richard.
Quote from: roverfj1200 on February 19, 2019, 04:54:48 AM
Good to know
By that logic, the 150 should be better. I can see the turn-in being easier, but there is certainly more contact patch on the ground in a turn with the 180.  :bomb: (popcorn)
Country Joe
It seems to me that the most valid way to compare a 170mm vs. 180mm rear tire is to have one of each, in the same brand and model and try them out back to back, in new condition. I know that I thought the 180 Dunlop Roadsmart 3 tire that I replaced the previous 170 Metzeler RoadTec 01 with felt  phenomenally better than the narrower tire. I know, a worn out apple to a brand new orange....... :sarcastic: And yes, the 180mm tire works perfectly on the YZF600R wheel..... :bye2:
1993 FJ 1200
Congrats on the wheel mod Richard, that's exactly the mod I did on mine - it's so simple, I'm surprised not more people have done it ??
I'm running a 170/60x17 BT023 on the back and have a 120/70x17 BT023 on the front (on a FZR 3.5" wheel).
The difference in steering feel and consistency/predictability on turn-in is really noticeable !
(Mind you, I'm also running with modified suspension front and rear too).
I'm running a 160 tire on my YZF600 rear tire conversion and have absolutely no complaints.  I really don't think there's a bad tire out there in a modern size.
roverfj1200
Quote from: Millietant on February 19, 2019, 06:28:50 PM
That sounds like a really good combo. Will be looking for a FZR front as well..
1988 FJ1200
Richard.
