Buffing aluminum oil pump cover, and other covers
Started by markmartin, April 14, 2010, 07:11:15 PM
Travis398
this looked as bad if not worse than yours when i started, a little out of focus but you can see jack stand in the reflection. kind of stands out a little because the stock covers aren't this polished.
Travis398
this cover was all corroded and scratched up pretty good, Bob put this on his belt sander with a scotchbrite pad, and in literally 20 seconds had nearly all the scratches gouges and corrosion out of it.
markmartin
Quote from: Pat Conlon on April 16, 2010, 11:54:25 AM
If you do remove the black, respray with Satin Black 600*-800* engine paint, and oven bake (cure) the paint prior to addressing the shiny finish.
I picked up some paint stripper and will pick up some semi -chrome polish this week. The black needs to be painted as well.  I wouldn't have thought of baking the finish before working around the fresh paint and handling the piece.
Travis, thanks for the pics.
Nice to see that it's possible to get a good finish and people do this.   I didn't know if I'd be wasting my time until I gave up and bought a new cover.
I'll post the results when I do it.  The pressure's on now!
Thanks to everyone for the input. :drinks:
Mark
Quote from: Pat Conlon on April 17, 2010, 01:57:05 AM
When you polish a flat surface of aluminum, you want it to end up looking like a mirror, and not the type of mirror you would see in a fun house.
Or the original Hubble mirrors, as it turns out...
Easier to make a brushed finish, which is faster to clean up and harder to make look bad....
Travis398
Quote from: andyb on April 17, 2010, 06:00:48 PM
yes it is a lot quicker, when i said 20 seconds for the brushed look about half of that was talking about which direction to brush it.
mz_rider
Does the small cover on the right side of the engine (end of crankshaft) have oil behind it? I want to polish - do I have to wait until an oil change.
Stuart
Travis398
Quote from: mz_rider on April 22, 2010, 02:47:29 PM
Stuart
no, you can take it off. there is a seal behind the cover. it is a quick and easy one to polish too.
No, it's ok to remove. There is a oil seal behind it. Cheers!
billwest
Sold it!
Travis398
markmartin
One of the bottom screw holes on the cover was cracked when I took it off--I was able to break it off with my fingers--so I ordered a new cover. (Damn P.O.'s) :biggrin: I did refinish the smaller cover on the other side. (pic) Took it off, applied paint stripper, and buffed it with a random orbital sander with a red and then grey scrungi pads then buffed it with 3M aluminum and Magnesium polish and repainted the black with high temp semi-gloss black spray paint.  I like the sheen that I got on the aluminum--there are brush marks similar to the OEM finish and not a mirror finish.  Looks alot better than it did before as it was pitted also.
I'm going to do the large cover on the right side this winter when I have more time.  I see on the parts schematic that this large aluminum cover comes out or appears to come apart from the rest of that cover and is sealed in with a gasket of some sort.  I'm assuming the oil must be drained also.  have you done this one also?  Anything I need to know that might not be obvious?
Travis398
QuoteI see on the parts schematic that this large aluminum cover comes out or appears to come apart from the rest of that cover and is sealed in with a gasket of some sort.  I'm assuming the oil must be drained also.  have you done this one also?
yes it does come apart pretty easy, just a rubber gasket to deal with, i took one apart just a couple of weeks ago. you will need to drain the oil.
Yamifj1200
As long as the bikes on the side stand you dont need to drain the oil to remove the clutch cover. HTH
Eric M
courtsdaddy
Check out the por-15 website you will find some polish that works amazing. I think the name is Artisian metal somthing, works great with a power ball and a good drill.
