Rear fender lengths
Started by T Legg, January 22, 2019, 10:48:29 PM
T Legg
I have two 84 FJ's that the serial numbers are only twelve apart but the rear fenders are different lengths.my first fj has a shorter fender which I think looks much better.It doesn't look like it's been cut down,if it was they did a heck of job there are no rough edges .has anyone else seen a rear fender that is short like that?
T Legg
The fender on the yellow bike looks to be of the OEM standard length fender. The two small holes are for a red reflector bracket. The fender on the black bike has been cut down and looks to have been done very well.
I cut my tail light and fender down...I think it matches the FJ's lines better.
http://www.fjowners.com/index.php?topic=1629.0
Agreed Pat, but only with the bigger tyre.
Cutting them down with the standard wheel /tyre just exaggerates its smallness & narrowness IMHO
Quote from: Pat Conlon on January 23, 2019, 01:42:10 AM
T Legg
Pat's tires are definitely wider than stock but I didn't think the tires were significantly if at all taller then stock.
T Legg
Quote from: T Legg on January 23, 2019, 02:21:24 PM
You are correct, sir. 150/70/16 = 24.3" diameter   180/55/17 = 24.8" diameter
TexasDave
Riding beside Pat at the Central Rally in S.Dakota, both of us on 84's with identical gearing I synchronized our engines. With both engines at the same rpm our speed was virtually identical. I still have a 16" rear tire and he has a 17". With a 16" tire with the higher profile side wall and his 17" tire with a lower profile the tires had to be the same diameter. The sound of two synchronized FJs is just as sweet as the sound of a twin engine aircraft.
Dave
I ride beside Pat once in a awhile, momentarily.  :)
Yep, the wider tyres on 17" wheels aren't any taller, but the extra 1/2" each side that the rim sits away from the rear hub has a big (positive) visual effect on the rear of the bike  :good2:
Quote from: ZOA NOM on January 23, 2019, 03:21:11 PM
Yea, for 0.05 of a second....I recall my helmet visor flipped open from the vacuum....you rascal.
Tuned forks
Pat I've often wondered but keep forgetting to ask, what application did your rear tire fender come from?
1990 FJ1200-the reacher
1990 FZR 1000-crotch rocket
The hugger was made by Pyramid Plastics in the U.K. It's for the YZF1000 (Thunder Ace) swing arm.
Unfortunately they don't make them for the FJ's swing arm.
https://www.pyramid-plastics.co.uk/accessories.html?catnum=100817&h=16_100471&d=YZF1000%20THUNDER%20ACE%20Huggers
T Legg
With out having that lower aftermarket fender I have had complaints from Ian about being pelted with small rocks on gravelly roads when he follows within fifty feet.At the time I didn't realize I had a short fender.
T Legg
Tuned forks
That sure looks cool Pat.  Now Travis has something else to buy. :biggrin:
