Repair of the Christmas roasted FJ
Started by aviationfred, January 07, 2019, 11:41:17 PM
Tuned forks
The Phoenix has risen.  Good job Fred.
1990 FJ1200-the reacher
1990 FZR 1000-crotch rocket
Old Rider
You did an Impressive save When the fire started!  nice looking carbs and bike :yes:
A productive day today. The replacement left side panel arrived. Installed the used oil cooler. It appears to be a RPM cooler that has never had oil in it. The brackets already had the mounting holes drilled. It may have been installed, but never ran. The hoses are fabric braided verses the stainless steel braided hoses on my previous RPM oil cooler.
Replaced both of the damaged side panels. No ABS logos, since the ABS system has been removed.
Troyskie
Did you get the cooler from RPM?  Along with the fabric braid the hose lengths look different.
On the coolers I've installed the hoses needed to criss cross to the opposite sides of the pan fittings.
Nice work Fred!   So happy you got that fire out before the fuel line melted.... :good:
Quote from: Pat Conlon on February 10, 2019, 02:19:56 AM
While trolling through ebay looking for replacement parts for the burned and melted pieces. I came across this USED oil cooler. I recognized it as appearing to be a RPM oil cooler with the Black fitting option. The add stated that it was installed on a bike that had been broken down for parts. The price was significantly less than a new RPM oil cooler, so I jumped on it. If it is not a RPM cooler, it is a well done clone.
I am pretty sure that is the RPM cooler. We supplied the black fitting with a nylon black braided hose at the beginning. But soon found out the black dye fades and the hose turns white. It has been a bunch of years since we have send one out like that.
Fred, you might see if the hoses fit better crossed as Pat mentioned. Also, you need to be very careful. The hose routing bracket you are using can put a lot of tension on the cooler and cause it to crack.
