CMR racing products F1 frame
Started by Indiana jones, November 22, 2018, 06:36:40 PM
Indiana jones
Ignition, tranny and clutch.
Motor in this weekend, hopefully.
BMW R1150GS,XT600 Tenere,FJ1100 bobber, Ducati 999 BiP x 2
JMR
Quote from: Indiana jones on April 18, 2019, 07:15:45 PM
I've been chatting to Roger Winfield about the best pistons, etc.
His super reliable motors run std xjr13 pistons in std bores with zero problems. Any engine failures have been attributed to pushing things a little bit too far in the revs.
I'm pretty sure he's run an engine for 2 seasons and a precautionary strip revealed minimal wear.
I'll be hoping to get around the 140hp mark with head work,full system, stage 1 Yoshi cams, Mikuni 38 flats and a Dyna ignition.
I have a beautiful lightened crank but I think this will have an adverse effect on power delivery.
I have some Nova close ratio gears to help close up the gaps between gears.
I'll be using a Barnett spring conversion till I can afford a Sigma slipper unit of work out how to convert a zx10r clutch, apparently super reliable and smooth.
You should get 140 HP without much hassle. I had 130 RWHP with a stock 87 FJ1200 engine that had Yosh Stage 1 cams, RS-38's and a Hindle 4-1 pipe. I set lobe center at 105 both intake and exhaust. I set the lobe centers at running lash....forget trying to get zero lash. Just subtract the lash from your opening #s. i.e. at zero lash intake suppose to open at 20 degrees BTDC. With .005" of lash the intake will open at 15 degrees BTDC.
And I agree....forget the lightened crank....I could go on about it but I won't.
The spring conversion kit is OK...I use 3 stiff and 3 lighter springs I sourced through Barnett. Clutch pull very reasonable but it holds 160 RWHP.
Indiana jones
Xjr1300 engine just to get up and running.
Interesting, can you offer the new tooth count for the gearing?
That might be something to look into for the future.
Here's something everybody can enjoy.
So far, there's nothing I don't like about this project.
Reminds me of a Harris special or those super saucy moto Martin kits they made in very limited numbers for the cbx sixers. Or even, dare I say it, the bimoto yb whatever it was.
Good luck with the build
Indiana jones
Quote from: racerrad8 on April 29, 2019, 07:08:33 PM
Not sure how big a difference there will be.
Apparently the teeth are "stretched " to achieve the ratio change.
Tuned forks
No wonder we are trying to shift into 6th gear.  5th gear is not a 1 to 1 ratio.
1990 FJ1200-the reacher
1990 FZR 1000-crotch rocket
Indiana jones
I'm failing miserably to get 2nd gear off the input shaft to get 5th off.
Its pressed on and the bushing on 5 needs replacing.
JMR
Quote from: Indiana jones on May 01, 2019, 04:42:25 PM
You using heat?
Indiana jones
Yes, I am.
Haven't reddened it yet.
Indiana jones
Coils mounted and wired.
Carbs(Rs38 Mikuni) plumbed and q/a throttle hooked up.
Almost ready for a start!
jscgdunn
Very cool project.....soon to be new winner of "Most Modified" :pardon:
90 FJ 1200 (Son # 2), Stock
Indiana jones
Build currently stalled due to Isle of Man mechanic duties.
Indiana jones
It's been a while since I updated, bit I had a bit of bad luck during the summer. :Facepalm:
My house, a 350 year old traditional farm cottage, burned to the ground.
Pretty much took everything I own with it.
I'm only getting back on track after the ordeal.
Thankfully, it was insured, but money can't replace what was lost.
Luckily, I didn't have my project on display in my sitting room, but I did loose my beautiful BMW, 1150Adv.
My Nova close ratio tranny and Barnett clutch were in the house, but I have another set located.
Hopefully, I'll be making progress soon.
Updates to follow.
Great results for Team USA at the Phillip Island Classic.
Mojo Yamaha and CMR frames doing the job.
