Fork inner tubes
Started by aj52, November 22, 2018, 11:04:32 AM
RPM - Robert
Yes, the mounting point is different to accommodate the ABS sensor. However the OD is still 300mm and the spacing is correct for the forks. You will need ABS rotors to use the ABS wheel but the caliper mounting brackets are the same for all of the non anti dive FJ forks.
aj52
The wheel is complete with all the necessary parts and spacers.
Those measurements that Randy gave, is that for the inner tubes?
Hannes
1991 FJ 1200 ABS
1991 FJ 1200
RPM - Robert
That is correct. Those are the length measurements by year for the fork tubes.
