Fuel pump
Started by Cameron123, November 21, 2018, 01:57:24 PM
Cameron123
I own an '89 FJ1200 that's attached to a Comanche Sidebike sidecar that I enjoy using this time of year in order to deliver Santa and his gifts.  Recently, it has not wanted to start.  I soon recognized that when I turn the ignition on, that I don't hear the fuel pump that normally runs for a few seconds - I assume until adequate pressure is obtained.  I verified that power is getting to the pump when the ignition is turned on.  I ordered a used replacement and am concerned that it doesn't work.  I plugged it into the bike (but did not mount it) and it did nothing when the I turned the ignition on.  Does it require me to hook up the actual fuel line before it will even run?  Is there another way to verify the used replacement fuel pump actually works?
Cameron Smith
Philadelphia suburbs
'18 BMW R1200RT
'89 Yamaha FJ1200W with SideBike Comanche sidecar
The pump should run with or without a fuel line connected. Make sure the Run/Stop switch is in the Run position and functioning.
TomJK
https://www.youtube.com/watch?v=ABd-Leis9xw
This helps prolong the life of the fuelpump!
Done this 12000 miles ago, running fine!
Cheers, Tom.
Past bikes : BMWR90-S,BMW R100CS, Ducati 900SD, Kawasaki GPZ600,Yamaha FJ1200,Kawasaki ZZR 1100 (4x),Kawasaki ZZR1200, Honda CBR1100XXX,Yamaha Thunderace, Kawasaki ZX10R (3X),
Aprillia Falco,Honda CBR600F4I, bikes today : Kawasaki ZX10R (C1, the best!),Yamaha FJ1200, soon to come Kawasaki Z900.....
