GSXR back rim.
Started by Paul.1478, November 05, 2018, 11:11:59 AM
TexasDave
The stock gearing on my 84 was 17 and 41. I changed to 18 and 40. It made slightly more than a 500 rpm difference at highway speed. Most of the guys that do a lot of highway riding go to a 18 and 39. Pat was running 18 and 40 on his 84 with the 17 inch rear tire mod. Riding beside him our speed and rpms where the same as the 17 inch tire has about the same profile as the 16 inch stock. 17 just gives you a wider selection of rubber with a wider tire.
Dave
Paul.1478
I do not want the 42 that's the issue.
89 gsxr 750 (the rim I will have )  smallert soroket is 42. I have to have one made.
Agree 62 is high compared to off the shelf but not bad for "custom" made.
2006 GL1800
2022 Ducati V2
1976 RD400
1993 FJ 1200 ABS
That's cool Paul, I understand re the cost  :smile:
I was just thinking that as standard is 40 teeth on the rear, anything more than that on your GSXR wheel will mean that your bike is revving higher than standard (and if you went for the 18 tooth front, the 41 rear will be negating some of the benefit of the front change)   :good2:
I found a 40T GSXR sprocket on eBay.
RPM - Robert
The 750 wheel has a 5 bolt sprocket not the 6 bolt like yours Rick. The 6 bolt sprocket will not fit.
Quote from: RPM - Robert on November 15, 2018, 10:39:55 AM
Well, that's just stupid. Will the cush drive with six bolts fit the 750 hub?
RPM - Robert
That I do not know. I actually thought they were all the same yesterday until Paul contacted me and said our sprocket would not work. Upon further investigation, our supplier only stocks 42T-48T sprockets for the 1989 GSXR750.
Guess he could ride wheelies everywhere if he wanted a cheaper sprocket.
Bones
I've got an 88 gsxr 1100 4.5in wheel that's got the six stud sprocket fitted. Strange how they went smaller for the 750 as it wouldn't exactly be lacking in power itself. Not sure if the Sprocket drive is interchangeable, I'm assuming it is and might be something to look out for as smaller sprockets are easily available for the six stud. I found a 38t sprocket for mine on EBay no problem at all.
93 fj1200
79 suzuki gt250x7
An 18t/42t is not a bad combo. That would at least get Paul on the road until a custom sprocket can be made.
True Pat, I agree.
18:42 is as near as makes no difference to the stock 17:40 sprockets.
Paul.1478
It only 4 days from order to delivery.
I'm not going to do it for a few months. I just got new tires installed.
Need to burn off the back ASAP.
Thank again guys. Great helpful group.
2006 GL1800
2022 Ducati V2
1976 RD400
1993 FJ 1200 ABS
T Legg
 My 84 fj1100 came with 17/42 sprockets and i still have those sizes on.I do admit I try to shift to sixth often on open roads but I've yet to top it out in fifth and i love the gearing when driving sporty through the mountains or when passing.I've never ridden another fj so I don't know what I,m missing.
T Legg
Hey Travis, yea, same here, I remember the 17/42 combo on my bike. That was a looong time ago.
The easiest way I have found to experiment on my '84, is to try a 18t counter shaft sprocket. See if you like it (you will) Your chain will like it for sure.
Changing the front sprocket is a snap, much easier (and cheaper) than the back sprocket.
Just before my big trip with Cap'n Ron this past summer, I installed brand new chain and sprockets. I went with 18/38
After riding that whole trip with those (6,000+miles) I am switching back to 18/40..............I may even try to find a 41, if anybody makes one?
The 18/38 combo is too tall for my liking. The FJ has no trouble pulling away from stops with these, and has plenty of torque to accelerate with them even in the higher gears.
Although I liked how this combo put the revs down in a lower range, I felt that it caused the engine to be "working" slightly harder during the kind of riding I like to do.
I noticed my fuel mileage to be slightly worse than with the 18/40 combo, due to me having to use a bit more throttle to maintain speeds, either on the Interstate, or into the wind.................especially loaded with gear.  I feel that it puts the revs below the "sweet-spot"
Anyway, that's just my findings. YMMV  :drinks:
ps:  I'll probably have a slightly-used (only just over 6,000 miles) 38-tooth rear sprocket for sale shortly.............
Quote from: Firehawk068 on November 15, 2018, 07:28:02 PM
I switched to 18/41 about 80,000km ago. It was one of those changes that I never gave another moments thought to, it was just right. As many here know, my riding covers a bit of everything from crawling along bush tracks in first gear to big, fast days and everything in between.
I can't imagine going a whisker either way being an improvement as an allrounder best option.
There is however no right or wrong with gearing, within reason it is entirely personal choice.
