FJowners.com
March 26, 2023, 02:24:16 AM *
Welcome, Guest. Please login or register.
Did you miss your activation email?
Login with username, password and session length
News: This forum is run by RPM and donations from members.
   Home   Help Login Register
Pages: [1]   Go Down
  Print
Author Topic: Slipping clutch? Check out the Clutch File section.  (Read 23992 times)
Global Moderator
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
« on: April 09, 2010, 04:32:36 PM »
Seems we have a lot of recurring questions on clutch slipping.
Check it out, hope I did not miss anything. This should help the new folks.
http://www.fjowners.com/index.php?topic=1808.msg14307#msg14307
Logged
2) Don’t store your FJ with E10 fuel https://tinyurl.com/3cjrfct5
4) Important items for the ‘84-87 FJ’s:
Alf
Hero Member
Offline Offline
Gender: Male
www.fj1200.info
WWW
« Reply #1 on: August 16, 2012, 02:09:34 AM »
And it works!  yahoo
Logged
FJ1200W
Bronze Contributor
Hero Member
Offline Offline
Gender: Male
Columbia, MO USA
« Reply #2 on: December 12, 2015, 06:56:21 PM »
Thank you sir!
Logged
Columbia, Missouri, USA, Earth
Life is a lot like motorcycles.
Motorcycles are a lot like life.
THXFJ1200
Jr. Member
Offline Offline
Gender: Male
Outside is where the fun is, where the bikes are.
« Reply #3 on: June 08, 2019, 11:03:33 PM »
 blush I might have a stupid question... -but my momma says stupid is who stupid does- so here it goes.
How does it feel when the clutch is slipping?
I am having the hardest time changing gears, like getting neutral is nowhere there, and first also very hard like kicking it down and I feel like I am destroying the thing.
Is this a sign of the clutch been slippery? I was thinking maybe some of the joins and axels need some lube or so...
I did anyways buy a shifting Detent kit from RPM and will give it a go to install it, but I know I have to remove the clutch anyway, so if this is a clutch issue I could already kill two birds with one shot.
How can I differentiate if the shifting issue is not the clutch? I am starting a thread right now but thought to give it a try here just in case. not trying to hijack this thread at all...
Just thought it should be nice to have a clear image for us new to this what to acknowledge as clutch slipping problems.
Thank you very much.
Ser...
Logged
Current: 1992 Yamaha FJ 1200 with ABS
Scooter Honda Elite CH150 fixer-upper
Suzuki Intruder VS800GL down in FL
Past:
Yamaha XT 350
Suzuki DL 650 "Wee-Strom" (first bike)
Global Moderator
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
bono malum superate
« Reply #4 on: June 08, 2019, 11:22:36 PM »
A slipping clutch is easy to test. Ride where you can accelerate hard safely. Perform WOT (Wide Open Throttle) pulls once you are in 3rd gear. A slipping clutch will allow the engine to spin up to higher revs quickly with no benefit of acceleration. Hard shifting may be a leaking clutch slave or air in the clutch hydraulics. This causes the clutch push rod to push less. This means the clutch plates are still dragging a bit so the gears still have load on them when you are shifting.
Test for clutch slip, then report back...
Logged
Cat Cracker
$ Contributor
Jr. Member
Offline Offline
Gender: Male
« Reply #5 on: August 06, 2020, 01:06:42 PM »
Thank You Pat.
Logged
Barry Lupton 1985 Yamaha FJ 1100
2001 Kawasaki ZRX1200R
1980 Yamaha RD 350LC
1984 Yamaha RD 350 YPVS
1975 Honda 400 Four Super Sport , Yoshimura Big bore Kit,           Box Section Swing Arm
1982 Kawasaki Z 400 J
1983 Kawasaki GPz 1100
Global Moderator
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
« Reply #6 on: August 06, 2020, 01:44:52 PM »
You’re welcome Cat, it was a group effort....
Logged
Waiex191
Hero Member
Offline Offline
Gender: Male
« Reply #7 on: August 06, 2020, 03:07:53 PM »
This is timely for me because I think my clutch is slipping at WOT and high RPMs. For now I'm just avoiding that bit of fun because 1) I want to get back to the airplane and 2) no problem keeping up with the V30 Magna.
Logged
Bryan
1981 Suzuki GN400
Poplar Grove, IL
THXFJ1200
Jr. Member
Offline Offline
Gender: Male
« Reply #8 on: June 06, 2021, 06:57:26 PM »
It was a leaky slave cylinder, its been fixed now, thanks.
Logged
Past:
Yamaha XT 350
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.10 :: SMF © 2006-2009, Simple Machines LLC
SMFAds for Free Forums
Valid XHTML 1.0! Valid CSS!
