Tank Sealant
Started by ryanschoebel, July 17, 2018, 08:21:00 PM
iridewheelies
I cut up a chain saw chain into 5-6 pieces. Filled the tank with vinegar and let it sit for a few days. Opened it up saw a film of rust on the top of the vinegar. Drained some out so it wasnt 40 lbs. shook it for 10 mins. Came back shook it for another 10 mins. Make sure the nuts bolts chainsaw blade (in my case) is rattling and knocking the rust loose. Hopefully you dont uncover a pin hold leak. Either way! Doest matter. Continue with the rust removal. Flush it out very well. Do it again. Flush it out until there isnt any more rust coming out, or a minute amount. I didnt really read the thread, im just telling you guys what i did to cure my rust problem. After the tank was clear and dried out very well, i went to orileys and bought red kote fuel tank liner. Follow the directions, make sure there is a good layer inside the whole tank. Drain out thoroughly and let dry and air out for a week or more. this fuel tank liner will plug any pin holes, and help seal any remaning rust.
