R1 Front Callipers
Started by Greg C, June 18, 2018, 04:27:51 PM
Greg C
I have been search the site but haven't been able to find an answer to my question. What year R1 callipers will fit on the FJ? Does the master cylinder need changed?
Sorry in advance.
The impetus for this question is that the Fj broke down and I ended up riding my dad's Bandit home and the brakes were incredible.
1990 FJ1200
Previous Bikes
1992 FJ1200
1983 GL650
1982 CB650
1980 CB750
1978 KZ200 (first bike)
Quote from: Greg C on June 18, 2018, 04:27:51 PMI have been search the site but haven't been able to find an answer to my question. What year R1 callipers will fit on the FJ? Does the master cylinder need changed?  Sorry in advance.  The impetus for this question is that the Fj broke down and I ended up riding my dad's Bandit home and the brakes were incredible.
Greg,
No need for apologies.   :yes:   There's a better way to search than the on-board Search utility.
I do not know the direct and complete answer to your question, but many riders here would recommend using two stainless steel-braided brake hoses to replace the fading old stock rubber hoses.  You can get a double-hose banjo bolt for the front brake master cylinder, to fit these hoses.  You probably do want new front brake lines by now, so you may decide that the calipers were never really the problem anyway, with new SS brake hoses.  Any decent hydraulics shop can make the new hoses for you, and they should have translucent color-tinted sheathing for these steely hoses as well.  You may find pre-made brake hoses on-line, too, but they could be pricey, with shipping.
You can tell Google to search any one site, rather than the entire Internet, if you use the SITE: command.  At the Search line on the Google web page, type in what you want to find, hit the spacebar,  then type in SITE: and the target URL.  It would look about like this:
Yamaha [R1] caliper SITE:http://www.fjowners.com
The [box] brackets are helpful too, telling Google that the results MUST include any such bracketed terms.  For your search, R1 calipers on this forum will probably get results related to what you want to see.
Happy hunting . . .
Yamaha used the same basic Blue dot calipers on multiple bikes of the same era. R1, FZ1, R6, FZ6 and FJR's used Blue, gold and silver dots. I believe the gold and silver dots differ, in that they use aluminum pistons versus steel pistons. Here are a few links to calipers that will work.
https://m.ebay.com/itm/09-Yamaha-FZ1-Front-Brake-Calipers-76A/152806128266?hash=item2393f47a8a:g:O-gAAOSw241YlUEI
https://m.ebay.com/itm/2002-2003-YAMAHA-YZF-R1-RIGHT-LEFT-FRONT-BRAKE-CALIPER-SET-PAIR-CALIPERS-W-PA6DS/253614403212?hash=item3b0c98ae8c:g:rIUAAOSwxuha9G7W
This last set comes with the attached master cylinder. Add a set of dual brake lines and you will have great brakes.
https://m.ebay.com/itm/03-09-2009-Yamaha-Fazer-FZ6S-600-front-brake-master-cylinder-calipers-brake-oem/173367730684?hash=item285d85a1fc:g:WDcAAOSw03lY6CbZ
RPM sells the 2 line set up that eliminates the splitter. And the ends are rotatable to prevent any twist preload on the lines. A dual banjo bolt will be needed at the master cylinder.
http://rpmracingca.com/proddetail.asp?prod=S-YA0146&cat=39
1990 FJ1300 (1297cc) Casper
Short answer: Don't fixate on R-1 calipers. You want the Yamaha monoblock calipers, axial mount.
As Fred mentioned above, many other Yamaha models use the blue/gold/silver dot, 1 piece monoblock calipers, not just the YZF R-1. To answer your question YZF R-1 up to 2003 used axial mounted monoblock calipers. Starting in 2004 and after, they used radial mounted calipers. You want the axial mounted calipers.
No, you do not NEED to up grade your master cylinder, however if you want the best feel from your front brakes, replace the FJ oem 5/8" (16mm) diameter piston m/c with a 15mm FJR m/c or even better, a 14mm m/c off the FZ-1 (and other models) The smaller piston, longer stroke m/c will give you much much better lever feel and control at braking threshold vs the larger piston/shorter stroke oem m/c piston.
What's good brakes without control?   The best brakes are meaningless without practice, practice, practice.
Here's more info. for you (this is a great site) http://www.fjmods.co.uk/BrakeUpgrades.htm
Hope this helps.   Pat
Greg C
1990 FJ1200
Previous Bikes
1992 FJ1200
1983 GL650
1982 CB650
1980 CB750
Greg C
So, after all of the advice I received I ended up going with 2001 FZ1 front callipers (got the set for a whopping $38 shipped) and a 2012 FJR master cylinder ($20 shipped). I already had the steel braided lines as I had planned on replacing the 28 year-old lines anyway. I have everything mounted up, bled, and it really stops now. As I changed so much at once it's hard to know how much difference each component made on it's own. I'm sure the new lines help a lot. I am really happy with the change (and that I had very little money wrapped up in parts).
The only issue I've run into is that the FJR master cylinder brake light switch seems to be wired completely opposite the FJ switch and the old FJ switch doesn't fit the FJR master cylinder. Does anyone know a fix for this?
Thanks!
Greg
1990 FJ1200
Previous Bikes
1992 FJ1200
1983 GL650
1982 CB650
1980 CB750
You need to either reinstall the original brakeline mounts that were held in place by the fender bolts or add some like sized washers where the mounts were.
Otherwise your fender tabs are going to crack
QuoteThe only issue I've run into is that the FJR master cylinder brake light switch seems to be wired completely opposite the FJ switch and the old FJ switch doesn't fit the FJR master cylinder. Does anyone know a fix for this?
http://rpmracingca.com/proddetail.asp?prod=M%2FC%3ABrakeLightSwitch&cat=23
Greg C
Thank you for that suggestion!
Quote from: FJ_Hooligan on June 25, 2018, 02:54:13 PM
1990 FJ1200
Previous Bikes
1992 FJ1200
1983 GL650
1982 CB650
1980 CB750
Greg C
Quote from: ZOA NOM on June 25, 2018, 02:57:44 PM
Excellent!
1990 FJ1200
Previous Bikes
1992 FJ1200
1983 GL650
1982 CB650
1980 CB750
oldktmdude
   Greg, if you haven't already done so, I suggest you fit EBC HH pads. These will probably make the biggest improvement out of all the mods you have already made, with the possible exception of the braided lines.
   Regards, Pete.    :good2:
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
Quote from: oldktmdude on June 25, 2018, 06:22:17 PM
Also available from our host...
http://rpmracingca.com/proddetail.asp?prod=M%2FC%3AFA123&cat=23
Yep, EBC HH pads are the bomb :good:
Remember, when switching pad compounds (e.g. organic to sintered) scrub the old transfer layer off your rotors.
Zip, zip with your cordless drill:
https://tinyurl.com/yatcr3s6
WHEN your fender tabs crack, this stuff is bullet-proof. I've used it for several different repairs from the fairing to the fenders, and it is awesome.
https://www.polyvance.com/PlastiFix-Kits-1/2501/
While we are spending your money.....
This will definitely help prevent fender tab cracks (and leaking fork seals)
http://rpmracingca.com/proddetail.asp?prod=M%2FC%3AForkBrace
You realize Greg, we could keep going.....and going......and going....
Speaking about fork seals, now let's do something about protecting your stanchion tubes from rock chips and bugs...Unfortunately RPM's bug shields don't work with the RPM fork brace and you really, really want the fork brace.
Avation Fred has you covered: http://www.fjowners.com/index.php?topic=14171.msg142954#msg142954
