1990 FJ1200 3CV Butchered Wiring
Started by Coyote86, April 04, 2018, 11:51:23 AM
Coyote86
Hi All
I have a 1990 G reg FJ1200 3CV. Im turning the bike into a bobber and used the manual to work out all the wires. Ive now cut the wires to shorten them and cut out any unwanted ones and now lost my homemade wiring diagram. Ive tried using the haynes and seem to come unstuck with a few extra wires or missing a few wires. Ive managed to get the bike to turn over but it does this if the key is in or out. Million dollar question is does anyone have a good wiring diagram for the 3CV and then hopefully i can get the bike finished. Its only took 5 years so far.
Cheers.
CutterBill
I'm working on a current flow diagram (better than a wiring diagram) for the 3XW models. It should be very close. I can send you the pdf if you like. Just understand that it may not be exactly like your bike...
Bill
Current Stable:
FJ1100
FJ1200 (4)
2015 Super Tenere
2002 Honda Goldwing
This is the minimum of what's needed to run the engine.  Not based on a stock harness though.  If this is a true bobber , it may be easier to wire from scratch.
http://www.fjowners.com/index.php?topic=16278.0
