FJ1200 engraved adjustable levers
Started by aviationfred, April 03, 2018, 07:19:54 PM
Quick update, I jumped on these engraved levers back when the thread first posted, and they arrived yesterday. I LOVE EM! 5 minute install, and they fit perfectly. The only hitch was the thread pitch for the brake adjuster bolt didn't match the OE bolt, so I luckily had a sweet stainless hex button head bolt in my "misc" jar that fit perfectly.
I love the engraving and the adjustability.
Clutch side
Thanks for the link Fred!
Quote from: FJ_Hooligan on April 04, 2018, 08:45:21 AM
I wasn't aware that the ABS bikes used different brake master cylinders.  I don't think they do
I thought only the brake light switch was different. That possibly makes the lever different?
:Facepalm:
Just figured this out when I couldn't see my brake light on my way to work this morning. I hadn't ridden the bike in the dark since I installed the levers. The brake light switch is on continuously, since there is no tab on the lever to keep it pressed.
I'll probably just modify the lever by adding a tab. The picture of the lever on Ebay seems to show a tab, but there's really no way to know what you're getting. Ill post a pic once I add the tab.
Rick, fit one of these, they cost $10. I haven't replaced a genuine switch on any bike for years, I use these.
Quote from: ribbert on April 24, 2018, 09:36:02 AM
Perfect! Thanks Noel!
edit: Am I looking for an M10 x 1mm thread?
Nope...A 2 wire switch will not play nice with Rick's ABS. The red ABS check light will start glowing.
You need a 3 wire switch (normally open /common/ normally closed) http://www.fjowners.com/index.php?topic=17650.0
Quote from: Pat Conlon on April 24, 2018, 12:13:24 PM
Uh oh... is this gonna be a mess? I had a simple idea for adding a tab to the lever...  Maybe it's time to delete the ABS. I plan to do that before installing braided lines anyway.
oldktmdude
Quote from: ZOA NOM on April 24, 2018, 11:26:10 AM
Rick, the thread pitch for the banjo's is M10 X 1.25mm
   Regards, Pete.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
fj-f3a
Quote from: ZOA NOM on April 24, 2018, 12:49:25 PM
Rick, why not use the Banjo Switch and a simple cross over relay?
Wings Level
1990 FJ1200, Wet Pale Brown
J17xMT5.5 rear wheel from a 2001 Kawasaki Zx9r
Stainless exhausts
Electronic cruise control
Custom seat
Yamaha R6 Blue Spot Callipers
FJR1300 Master Cylinder
Stainless brake lines
Quote from: fj-f3a on April 24, 2018, 06:45:25 PM
Good call Gavin. That would get Rick back on the road until such time he does the ABS'ectomy.
Rick, let me check something first. I mentioned the normally open / common / normally closed because that is what I remembered when working on Jason's '93, *but* I may wrong (it's happened)
The switch may be normally open / common / normally open design.
We know one side of the 3 wire switch sends 12v power to the tail light.
We know the other side of the 3 wire switch signals the ABS ecu, but not sure if that's normally open or normally closed.
You can check your switch to see....
I went the simple route for now. Tie-wrap around the switch and use the rear brake for the brake light. Now I can brake without alerting anyone behind me, he he... :)
Once I rip out the ABS, I'll be in business. Also, I think there are levers on FleaBay that actually have the tab, which would be the best route. They're under $30, almost disposable at that price.
edit: Thanks for the info, Pete
Rick, just an FYI, yes it's a normally open / common / normally closed switch
Quote from: Pat Conlon on April 24, 2018, 10:47:14 PM
Thanks Pat
Charlie-brm
Other buyers; how long was it between ordering and arrival?
I got my first tracking notice and it shows Shipped May 5 - Estimated Arrival July 5 >>> 2 months.
China sellers give themselves a lot of lee way but other stuff I've bought (Gearbest, Aliexpress, DX) barely took a month.
I didn't get the impression from this thread that anyone had to wait 2 months to see their levers.
1979 XS750SF - 2005 to 2012
Sounds like a slow boat... Mine was less than a month.
Jeff0308
I cheated. I used self adhesive chrome decals with clear film.
