"New FJ" troubles
Started by aj52, March 05, 2018, 01:10:02 AM
Connect a clear tube to the float bowl drain screw, bend the tube so it's pointing up next to the float bowl gasket line, open the drain a few turns  and use that to see what the actual fuel level in the bowl is while the fuel pump is on.
aj52
 :morning2:
Quote from: FJ_Hooligan on July 28, 2018, 08:05:09 PM
Thanks for the tip,will check it like that prior putting it back
1991 FJ 1200 ABS
1991 FJ 1200
aj52
Took the bowl of today and remove the float.
And what do I see....there sits the o-ring piece that sheared off when I installed it,fine piece as the carb body cut it.
Other thing I saw was that the rubber tip has a 'ring' where it seals.
Thanks for everyone that gave their inputs and special to Randy for pointing out for what to look for.
Is like he said,there are small things to look out for.
Hannes
1991 FJ 1200 ABS
1991 FJ 1200
ryanschoebel
Glad to hear you were able to find it!
1985 FJ1100-- Atlas (SOLD)
1984 FJ1100-- Storm
I called it...
Quote from: Pat Conlon on July 27, 2018, 03:38:19 PM
Common cause: Fuel leaking past the o rings on the float needle seats. Replace those.
If they are already new, they are easy to damage if installed incorrectly.
Jelly donuts for meeee :dance2:
aj52
Quote from: Pat Conlon on July 29, 2018, 04:10:22 PM
I called it...
There you go Pat,thanks a lot
Hannes
1991 FJ 1200 ABS
1991 FJ 1200
oldktmdude
   Lubricating "o rings" with rubber grease or other suitable lube should stop this kind of damage whilst installing "o ringed" items.
   Regards, Pete.   :good2:
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
Motofun
I bought a gallon of RUGLYDE from the local NAPA store.  Rubber lube for everything from mounting tires on rims to o-ring installation.  A gallon will last about 7 life times. :biggrin:
'75 Honda CB400F
'85 Yamaha RZ350
'85 Yamaha FJ1100
'89 Yamaha FJ1200
'09 Yamaha 125 Zuma
'13 Suzuki GSXR 750 (track)
'14 Yamaha FZ-09
'23 Yamaha Tenere 7
aj52
This was the first one I've put in.I should've use oil.on it,but didn't. The other 3 I did,because I've felt the first one was a bit hard to assemble. So actually I should have known that it sheared. Learned my lesson on o-ring installation.
1991 FJ 1200 ABS
1991 FJ 1200
aj52
Should the carbs be at 90° when doing this.
And what height should the fuel be in the bowls when filled up
I'm going to use same method to set the floats as I've done it the first time as describe by Randy's post in the files section
Hannes
1991 FJ 1200 ABS
1991 FJ 1200
aj52
Quote from: aj52 on July 30, 2018, 05:31:08 PM
Hannes
Please ignore,found my answer.
Lift front till carbs are level.
The height in tube should be at around 5mm from the top of bowl
1991 FJ 1200 ABS
1991 FJ 1200
Sparky84
Here's some pictures of mine.
1979 Kawasaki Z1300
1972 Honda CB750/4 K2
aj52
1991 FJ 1200 ABS
1991 FJ 1200
Quote from: aj52 on July 28, 2018, 05:16:22 PM
.......It only leaks when the fuel pump is running. If I switch ignition off,the leak then stops.
Hannes
I've had good success with persisitent carb leaks after full rebuilds with this......
Before
Polishing out this divot
After
The angle of the carbs won't matter if you make the measurement at the approximate center of the float bowl.
The fuel level will pivot around a fixed point at the center of the bowl.
If the carbs are tilted forward, the level will be higher at the front and lower at the back, but at the center, it will not move.
