Nothing lasts forever...
Started by ribbert, February 22, 2018, 07:26:15 AM
This is the back of my Garmin Zumo 660 after 220,000km. The pins have worn right through the brass contacts.
Does anyone have a dead 660 that don't want laying around? I only need if for the casing. Postage from the US is not a problem,
Thanks
Looks like you could drop a dab of solder on there for some extra miles?
FJ1100mjk
Iron Balls #00002175
www.ironballs.com
Thanks guys, I had considered both options. The solder is a bit soft and the conductive glue I have is very thin. If I can't get a case I'll see if I can get thicker glue, if not I will solder them.
Thanks for the input.
oldktmdude
   Noel. what about punching out some copper or brass shim material with the appropriate sized wad punch and use the liquid solder to attach them to the worn areas.
Just a thought mate. See you soon.   :drinks:
  Regards Pete.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
Quote from: oldktmdude on February 22, 2018, 07:15:54 PM
  Regards Pete.
Good idea Pete, I have sheets of different thickness shim material. The small size and the thickness required might make it difficult to get a clean cut but I'll give it a try.
Thanks
oldktmdude
   You probably already know this Noel,but I'll suggest it anyway, use a smoothly cut hard timber (ironbark, yellow box grey gum etc) end grain as the cutting anvil.
Makes a big difference to the cut finish. Also razor sharp wad punches. I know you will already know how to do this but thought it might come as good advice to those who have not tried this method of using wad punches.
   Regards, Pete.   :good2:
2009 TDM 900
2004 GasGas Ec300
