..... dirty clutch fuild ??
Started by Brook, March 30, 2010, 04:08:09 PM
Brook
...... I just bleed the clutch and front brakes, ... Can someone tell me why the clutch fluid is very dirty and the front brake fluid is very clean??............ both were done at the same time, last time.
........ Both are after market masters [Shindy] and with stainless steel braided lines and using Prestone brake fluid.
              Thanks, Jeff
Leaking clutch slave, non-leaking calipers.
What Andy said!
Suspect/Inspect the slave cylinder immediately.
Brook
