Black Widow Products
Started by FJ1200W, October 19, 2017, 06:23:15 PM
Troyskie
FJ1200W
Quote from: Mike 86 in San Dimas on November 06, 2017, 10:29:32 PM
Nice looking bike. Like the paint. Whats going with air scoops? You did something smart there. No annoying protectors to fall off.
I just noticed that on Mike's bike - does look nice!
Columbia, Missouri
USA
FJ1200W
Columbia, Missouri
USA
FJ1200W
I just read where some others had problems with the Black Widow mid-section, I'm trying to figure out why.
On mine, I installed the headpipes into the midpipe off the bike, raised the assembly into place, lightly installed the hardware.
Then I installed the mufflers, aftermarket Kerkers, again, not tight.
After everything was in place, then I tightened the headpipes to the head 1st, headpipes to center 2nd, the midsection to the frame next. Then position the mufflers and tighten them.
Maybe there are variances between models, I sure don't know.
All I do know is mines on and I'm diggin' it.
Plus they sent me a free hat a couple weeks ago  :yahoo:
Columbia, Missouri
USA
Bezmozek
Quote from: FJ1200W on January 07, 2018, 04:59:04 PM
..I'm trying to figure out why...
Not all angles were correct, to mount silencers, force was needed to fit those back. Mine were facing more outwards to sides but gasket can handle that.
Cyl. no2 I was unable to seal as downpipe was approx 10deg. wrong.
Was OK for a while, but after few heat/cool down cycles, air leaks occurred.
If you want to tighten more, flanges will bent. Threads on studs are not long enough, spacers/different studs needed
Belly pan will not fit as their headers are more forth
It will not fit with FJ1100 headers as those are slightly different(shorter) than 1200 although on their website stated as FJ1100 bolt on replacement.
see cyl 3 header still fully inserted in collector and OEM one too short to fit. You can not bent it upwards because of oil pan.
Double wall downpipes were used only on ´84 &´85 FJ1100.
But I think you don't have to worry if you want to use blackwidows on 1200 as 1200 headers are longer compared to 1100,
but haven't experienced as now i run 1TX downpipes and Delkevic collector with no issues :yahoo:
All story here: http://www.fjowners.com/index.php?topic=16968.0
´85 FJ 1100
FJ1200W
Quote from: Bezmozek on January 07, 2018, 06:00:31 PM
Sounds like you had some issues, I had none with the midbox alone, thank goodness!
Columbia, Missouri
USA
I can't comment on your particular issues, but an absolute golden rule of fitting exhausts, to anything, is to loose fit everything first. Bang everything around until it's settled and then progressively tighten from the front back. No exhaust joint or mounting point should be under stress and nothing should ever be "pulled" in by the fasteners, it will vibrate, probably leak and over time will crack.
You would be amazed just how much an exhaust can appear out of alignment by incorrect fitting sequence.
