'84 - '87 FJ 1100/1200 Parts for sale
Started by fjsforever, October 16, 2017, 11:52:01 PM
fjsforever
Parts for sale as listed:
'84-'85 Yamaha FJ1100 - coils, wiring harness, ignition box, electrical components, rear subframe, fairing stay, assorted frame rubber mounts/grommets,OEM brake calipers (f & r), footrests, front forks, triple trees, rear shock, front/rear OEM turnsignals, complete engine, generator, starter motor.
'86-'87 Yamaha FJ1200 - coils, ignition box (49 state), RH handle switch, OEM brake calipers (f & r), footrests, assorted frame rubber mounts/grommets, front forks, triple trees, rear shock, rear OEM turnsignals, windscreens, ('86 & '87) fairings, '86 plastic frame sidecovers, LH footrest stay, generator, OEM wheels, OEM seat (needs cover), '86 fuel tank.
FJ1100/1200 Performance - Falicon clutch basket, PM front wheel (3.5x17), Vance & Hines SS2R 4/1 pipe (VG), Nissin calipers & adapters to run them on '84-'87 front ends w/320mm rotors, bad ass fully braced JMC Prostock +2"-+8" extended swingarm. I also have an unpainted smoothed out fiberglass lower fairing - 1 piece for either the FJ1100 or 1200  (you'll have to figure out a way to mount it).
Looking for: '87 rear cowl & sidecovers - need to be vg to excellent.
Located in San Jose,Ca. Please PM for pics or inquiries....Tks
WickedFJ1200
Do you have the Left side Ram air intake fairing?
ajacstern
