Stiff Shifting
Started by RobbieKNobbie, September 13, 2017, 09:44:01 AM
RobbieKNobbie
When I bought my (new) '89 FJ1200 a few weeks ago, it had it' s fair share of problems for a 3 decade old sport bike. That's to be expected, and really, overcoming these little issues allows a new owner to better know their bike better.
Well, one of the issues I had was an overly stiff shifter. I mentioned it here and some folks gave some good suggestions but none of them quite hit the spot. Fast forward to yesterday and I'm taking the shift linkage off the bike to remove some of the rust that's on the surface of the chrome plating. When I take the rubber boots off the rod ends, it's all rusty inside there! I mean *inside* the spherical joint itself. Furthermore, the shifter pivot is all corroded as well. a few minutes flushing the rust out with wd-40, followed up by blowing out the wd-40 and working in some thick lube oil has made all the difference in the world. She now shifts as light as a feather, and I feel I deserve a good self-kicking for overlooking basic maintenance before complaining about the unfriendly characteristics of such a fine motorcycle.
So the lesson here is, maintenance, maintenance, maintenance!
Key words: Stiff shifting, hard shifting, stuck shifter, gear change, gearbox
'90 FJ1200, '00 GSF1200, '90 ZX-10, '94 Virago 750
balky1
Quote from: RobbieKNobbie on September 13, 2017, 09:44:01 AM
When I noticed your 'Stiff Shifting' title, the same thing you did was first that crossed my mind. When you ride it continously you don't notice the subtle changes in hardness, but when you lube it - OMG.
Try it also on the levers and the rear brake lever.  :biggrin:
FJ 1100, 1985, sold
FJR 1300, 2009
RobbieKNobbie
Yup, the day after I bought the bike I lubed all the levers and cables, even the rear brake, but for some reason I neglected the shifter :scratch_one-s_head:
This winter I plan to take her off the road for a couple weeks for a light tear-down to get rid of all this surface rust, re-paint the bodywork, and replace all the suspension bearings. I'm a little afraid of what I'll find around the rear shock - it doesn't look like the previous owners were too diligent with the maintenance.
timleslie1957
Wow.  Going to put that on my list for winter work.  Great input!   :mail1:
Tim Leslie
"A bike and curvy roads ... priceless."
TexasDave
My girlfriend says she doesn't see anything wrong with having a stiff shifter..................especially at my age.   :pardon:
Dave
Quote from: TexasDave on September 14, 2017, 10:56:02 AM
Dave
Providing you can get it into gear.
Quote from: ribbert on September 14, 2017, 05:31:34 PM
Dave
Providing you can get even get started.....
PaulG
Quote from: RobbieKNobbie on September 14, 2017, 08:45:26 AM
... I'm a little afraid of what I'll find around the rear shock - it doesn't look like the previous owners were too diligent with the maintenance.
Don't be afraid but be prepared to be befuddled. The relay arm on my '92 shrunk to 1/2 it's size once I scraped 23yrs of road tar & chain lube & gravel off it. Had to replace the 5 needle bearings inside - along with every other bearing in the pic.  Will improve handling substantially. No more wandering on long sweepers and off ramps.
Ok back to shifting now...
1992 FJ1200 ABS
YouTube Channel Paul G
Flynt
Quote from: Pat Conlon on September 14, 2017, 06:48:36 PM
Dave
Easy Pat...
Sparky84
Dave
Maybe it's because your doin the shifting...
1979 Kawasaki Z1300
1972 Honda CB750/4 K2
Dave
Shouldn't be a problem, he's got the pull start model.
Bones
Quote from: ribbert on September 14, 2017, 11:16:45 PM
Dave
That's ok as long as it's not a two stroke. :biggrin:
93 fj1200
79 suzuki gt250x7
FJ1100mjk
Dave
Quote from: Sparky84 on September 14, 2017, 09:56:39 PM
Hey Dave:
Don't be concerned with the negativism, these guys are just relating their own personal experiences!  :rofl2:
They'd probably be lucky if they can even pee out of it anymore.
Iron Balls #00002175
www.ironballs.com
rlucas
Quote from: FJ1100mjk on September 15, 2017, 04:49:16 AM
Just don't stick it in "Reverse" by accident.
And it's not whether we can pee out of it any more. We can. A lot more frequently than it used to require, trust me on this. You'll see.
FJ1100mjk
Quote from: rlucas on September 15, 2017, 07:17:31 AM
As usual, there's help for the afflicted. In this case, the BPH Boys.
Now who from this forum, does the fourth guy from the left look like?
www.ironballs.com
