Crankcase Ventilation
Started by david f, September 05, 2017, 12:04:26 PM
david f
Hello all. I want to go to 4 individual air cleaners on an 84 FJ1100. What should I do with the crankcase vent tube? Is there a filter or valve that can be installed in that vent hose? Thanks.
David Foote
Tor-King
Hi David.  Yes, you will need one of these to substitute the airbox deletion:
http://rpmracingca.com/proddetail.asp?prod=Engine%3ABreatherFilter&cat=39
This is the guy to buy from for all your needs and wants...
Have a good one and welcome,
1993 Yamaha FJ1200
1988 Yamaha FJ1200
1986 Yamaha FJ1200
1984 Honda Nighthawk S 750
1972 Yamaha XS-2
1972 Honda CT70
1974 Honda CT70
1992 Yamaha DT50 MX
2012 Honda CBR250R
2008 Honda CBR125R
aussiefj
Hi David, I have the individual pods on my '93 but found the crankcase filter can get messy after a while and in traffic on a hot day I can smell oily fumes. I have resorted to this expensive set up. An old chammy leather container and about a $1 worth of tubing and some foam off of an old foam filter just to add a bit of restriction between the carbies and crankcase breather. I think this gives a setup similar to the original airbox system.
"It's a fine, fine line between pleasure and pain" - the late great Chrissy Amphlett & Divinyls. Never truer than when you're pushing hard on the bike. A good song to keep in the back of your mind.
An option that Randy at RPM showed me was to place the breather filter up between the intakes of carbs 3&4. As vapor escapes, the carbs suck it back in much like the air box set up.
JMR
Quote from: FJmonkey on November 30, 2017, 09:29:02 AM
That's what I do.
