Steering stem nut
Started by ArcticFJ1200A, July 20, 2017, 05:23:45 AM
ArcticFJ1200A
Does anyone of you know if the steering stem nut is one piece only or if it consist of separate cap and nut? Need the cap off to install a fork stem yoke 1" Ball Mount for my navigation unit.
Thanks
FJ1100mjk
Iron Balls #00002175
www.ironballs.com
ArcticFJ1200A
Quote from: FJ1100mjk on July 20, 2017, 06:43:56 AM
It's one piece.
Thanks. I'll put in my lathe then, to remove the cap the hard way :)
I just drilled a hole through the center of the cap. Put the bolt for the RAM mount through the hole with the nut up inside the cap. Tightened it down. And epoxied the nut up inside the cap. I put a little oil on the the threads on the bolt just in case. Been in use for years.
