Ground wire
Started by yambutt, July 19, 2017, 09:58:16 AM
yambutt
Have a 1992 fj and removed both my starter wire and ground wire that is connected to the engine, starter wire is easy to figure out but where does the ground wire connect to the engine, i seem to have forgotten.....thanks
Bolt it to the first engine case bolt that it can reach.
Usually one of the bolts on the top of the case at the rear of the engine.
I recall that the bolt points directly down in to the case.
yambutt
Thanks yall, that is it, just making sure
