Horizontal adjustment of Head light 1987 Model
Started by wainot-Phil, July 14, 2017, 07:18:28 AM
wainot-Phil
Hi all ,,It says  in my workshop manual that the Horizontal adjustment of the 87 FJ1200 Headlight is made by turning the Philips headed adjustment rod that is coming out the Bottom Left hand side (looking at the rear of the light). Is this correct ?? .I have turned this rod and it moves the light sideways ,, ,,  NOT up and down ,,,,My light also has another adjustment at the top right corner (which has a long rod with swivel joint and has a Plastic handle on it) ,,which is stuck and (WILL NOT TURN) .. What do I need to do to be able to lower my Light Beam down a bit ,,thanks for your help
""Past Bikes""
Suzuki Stinger 125
Honda 350/4
Kawasaki Z1000
Suzuki GS1000
Kawasaki GPZ900R
Yamaha FJ1100 84
Yamaha FJ1100 85
1990 FJ1200  Pinky
2006 FJR1300
1980 GS850
Z500 /4
XJR1300
"""Present Bikes""":
FJ1200  94
GSX1400
Country Joe
The adjuster on the right with the plastic knob is the vertical adjustment. You may have to try to get some kind of penetrating oil into the threads in the headlight housing to get it free again.
1993 FJ 1200
Charlie-brm
Go easy on that rod drive contraption. You can lube it as suggested but most of the resistance is from friction with the housing. That swivel is a U joint and if it is like my 1984, it is made of thin brass, i.e. easy to crack the wings of the U joint. You might try removing the screws that hold the rod to the underside of the fairing so you can get a better grip on the knob. Next step is drop the whole fairing and get access to the headlight housing so you can see what's stuck. For example, grip the part coming out of the housing before the U joint and apply your twisting efforts there.
1979 XS750SF - 2005 to 2012
