Animated CV carb video
Started by aviationfred, July 05, 2017, 12:54:28 AM
This is a pretty good animated video of how a CV carb works.
It is a Harley carb, but it still is a good video
https://youtu.be/IBFq9nHVmks
Urban_Legend
It is a good video. It helped me to track where I was going wrong, just by seeing how it all worked.
Mark
Mark
My Baby (Sparkles)
84 FJ1100/1200 motor
84 FJ1100 - Project bike.
balky1
Only difference here, as I can see, is the fuel mixture screw which doesn't have the same role in FJs?
FJ 1100, 1985, sold
FJR 1300, 2009
jdvorchak
Quote from: balky1 on July 05, 2017, 01:28:46 AM
With all due respect I disagree. It has the exact same effect on the FJ. Since both have the mixture screw, on the engine side of the side, opening that screw increases the fuel flow and richens the mixture. If the screw were on the air cleaner side, of the carb slide, it would adjust how much air is allowed to flow. So just the opposite effect and leans the mixture if opened.
Don't fix it until it's broke!
The only difference that I see with the air fuel mixture screw is the location. Ours is 180 degrees to the top.
jdvorchak
Quote from: aviationfred on July 05, 2017, 07:30:30 AM
By design I'm sure. Our inline 4's have open access from the top side. The Harley has the open access from the bottom.
balky1
According to files that I read here, mixture screw on the FJs only adjusts the amount of pre-mixed air/fuel that enters the engine (pilot and air bleed jets being responsible for the mixture itself i.e. for the air to fuel ratio). It doesn't shut of the fuel flow in the pilot circuit like here on the video. Or maybe I understood it wrong. Not that it matters much.
FJ 1100, 1985, sold
FJR 1300, 2009
