No spark
Started by jseaman, June 25, 2017, 03:26:49 AM
jseaman
Hi all,
I inherited a project a couple of weeks ago in the form of a '93 FJ1200. It hadn't been on the road for a few years and needed a lot of work. This is the first bike stripdown I have done so a bit of a learning curve (they're very fiddly!), but I have sorted the frame, new sprockets, fork seals, filters etc.
Before I did anything I got it running but it was very slow to fire - it cranked well and the fuel pump was obviously working but it wouldn't run. Eventually it did fire up and that was good enough for me so I set to work expecting that the hand tight spark plugs and mouse nest in the air box would be contributing factors to not wanting to fire.
Now I've come to the reassembly stage and I have good cranking, fuel pump whizzing away to the point it's coming out the overflows but no spark at all. The coils are connected and the 10mm bolt underneath has a ground connection to it, I'm assuming the ignition module in the front fairing is the next port of call but thought I'd see if I could get any pointers before I blindly attack it
James
jseaman
Just a quick update - I have taken a look at the kill switch after reading a few posts and it looks good
I've got 12V to both sets of coil wiring
The pick up looks reasonable (although needs electrical testing)
Before, during and after pics just for fun:
jseaman
The plot thickens, I've got a couple of Ohms over the primary coil and open circuit over the secondary
So my question is now - what would cause both ignition coils to pop at the same time?!
Quote from: jseaman on June 25, 2017, 04:37:01 AM
^^^ What did the test on the pick up coil show? That will affect both coils. Check and clean all the connections to the DCI igniter box?
The run/off handlebar switch may be in good shape but what about the wires running to and from the switch? Fuse box to switch. Switch to DCI box. That circuit powers the DCI box and if you have a loose or bad plug connection or bad wire in that circuit = no spark.
You can always run a test jumper from the battery + to the DCI igniter to assure that the box is getting full 12v power.
Read your wiring diagram to see which wire is the 12v input to the DCI box. Don't cut the wire, just (carefully) skin the insulation back and use a alligator clip.
Electrical gremlins are fun especially when you factor in rodents.
jseaman
Hiya,
Thanks for the feedback I went to measure the pick up and found it kind of wasn't plugged in :) Well, to be precise it was plugged into the wrong connector (which it will happily fit in), so the question becomes what should this be connected to - just next to the fuel pump wiring:
It fired on the first turn when it had a crank signal!! Although it doesn't explain why the coils are o/c
And yes, rodents add to the challenge :)
Quote from: jseaman on June 25, 2017, 03:26:49 AM
I inherited a project a couple of weeks ago in the form of a '93 FJ1200. <snip>
Not sure what's causing the loss of spark, but if the fuel pump is forcing fuel out of the overflow then you've got additional carb related problems.
Been a while since I ohmed coils but shouldn't the secondary ohm as open since it "shorts" to ground across the spark plug gap?
Also, I remember getting funny readings on the primary side if the power wires are hooked up.
jseaman
The fuel was being forced out because the pump was forcing fuel in every time it primed
The primary wires were disconnected when testing (they need to be really, that measured through fine
I believe the secondary is supposed to be ~15-20KOhm but can't get anything on it
My remaining question is about the plug, what should it go to?!
Quote from: jseaman on June 26, 2017, 05:56:31 AM
^^ Wrong answer
jseaman
Quote from: Pat Conlon on June 26, 2017, 11:03:31 AM
^^ Wrong answer
Very helpful?!
Anytime fuel is forced out of the carbs is an abnormal condition. Something is wrong. Most common cause is debris in your float needle seats preventing them from closing along with a possible stuck float. Also common are the O rings on your float needle seats become dry and hard and thus start leaking.
As Hooligan states above, you have carb issues. Time to clean your carbs.
Buy this kit: http://rpmracingca.com/proddetail.asp?prod=carbkit&cat=24
It has all the o rings you need to have at time of carb cleaning. It also has ss allen screws that will replace all those frozen soft JIS screws you will knacker when you try and loosen them.
There is an unused plug on the right side of the harness. This plug is used for the vapor recovery system on certain USA models.
jseaman
Now that's helpful, thank you
balky1
Quote from: Pat Conlon on June 26, 2017, 12:16:40 PM
Anytime fuel is forced out of the carbs is an abnormal condition. Something is wrong. Most common cause is debris in your float needle seats preventing them from closing along with a possible stuck float. Also common are the O rings on your float needle seats become dry and hard and thus and start leaking.
I see you guys have a lot of problems with carb screws. Although they are soft, I think we in Europe have a bit different screwdrivers? At least I've got ones that fit in the heads perfectly.
PS. For some reason I thought jseaman is from Europe, but I must have mistaken him with someone else. Sorry.
AHHH! Now I see! British licence plate. I don't know what type of screwdrivers they have (like they are not in Europe  :wacko2: ).  :dance2:
FJ 1100, 1985, sold
FJR 1300, 2009
jseaman
We're still in Europe :)
Yes England
The connector was for the rear brake, just found it
