clue for abs
Started by JOMPPA10, May 29, 2017, 10:59:18 AM
JOMPPA10
Permatex glue work in abs plastic , ive seekiing glue whith work on abs that its...sold as platic bonding
ive using 2yrs some places and no crack  :flag_of_truce:
ABS glue, common use on residential drain/waste/vent piping. Every hardware store carries it.
ABS glue works great when it bonds two mating surfaces like pipe fittings. But not so good for gluing on broken tabs and cracks. If you can use an extra pieces of ABS as a support surface piece then it should work well.
