Ignition advancer ready
Started by Alf, May 25, 2017, 02:18:38 AM
Alf
More than 10 years I have kept in my wardrobe this Factory ignition advancer, waiting for to be used in a FJ 1100 or in my "new" 1200 1TX
It is no more available from Factory, I think
pajo99
how much this advances ignition?
Alf
FJ1100mjk
Probably be able to wheelie in second and third gear, after installing it. Good for another 15 horsepower@10,500 RPM.  :rofl:
Iron Balls #00002175
www.ironballs.com
Alf
Quote from: FJ1100mjk on July 15, 2017, 11:38:49 AM
:rofl2: :rofl2:
But.... iots true that the middle power ooomph increase a lot, just where you use the engine
A popular mod in the '80's I've had one on my '84 for years.
Vance and Hines and Factory Pro both made these advanced rotors.
First thing I noticed was a slight ping on long up hill grades (with stock jetting)
#40 pilots and Shimmed needles made that go away.
She seemed to start quicker, but that could have been from the coil relay mod.
Country Joe
1993 FJ 1200
I recall not feeling any noticeable difference when I installed my V&H rotor.
Country Joe
Quote from: FJ_Hooligan on July 15, 2017, 07:26:14 PM
Was that on your 85 or your 93?
1993 FJ 1200
'85
I gave you all my '93 spare parts.  :-)
Bezmozek
Is there dyno from 3º/5º changed timing?
I am not into top end performace, but is there some noticeable gain in mid rev?
´85 FJ 1100
Alf
The gain is mainly at the midrange. In fact, increase the compression
Bezmozek
Thx Alf,
you do have oil temp gauge?
Is there a big difference in temperature with ignition advancer?
´85 FJ 1100
Alf
I cant say if with the advancer the bike run hotter because my 3CV bike have fitted a bigger rad, and another improvements
And my 1TX is going to exit from the refurbish with a bigger rad too, so I cant get an specific verdict
Travelling side to side with a friend with another 3CV with oil temp gauge fitted too but with std cooler and with no mods, both bikes always were at similar operating temperatures
Quote from: Bezmozek on July 21, 2017, 01:19:13 PM
5 deg advance will make no difference to running temps. Retarded ignition causes hot running.
IMO
