What Other bits to do when replacing rear shock?
Started by Sparky84, May 21, 2017, 07:08:36 AM
Sparky84
I think it may be time to update OEM rear shock on my 84FJ?
Now while I'm replacing shock what other bits do I need other than the shock, does it come with everything I need and just bolt it in?
Cheers Alan
1979 Kawasaki Z1300
1972 Honda CB750/4 K2
camo
I replaced mine with a Nitron shoc a few months ago, is a straight swap, but worth checking/ greasing up the roller bearings on the mounts while your there.
I would plan on a complete disassembly of the swing arm and all the shock linkage for servicing.
Unlike the '86/87 FJ's that have needle bearings in the shock linkage, the early '84/85's only have nylon bushings which *must* be lubed.
I recommend a vented shock boot to protect your shock.
http://www.traxxion.com/Vented-Shock-Sock-by-Traxxion-Dynamics/
I looked at RPM but I did not see a listing for a shock boot. I know Randy has them because they come with his new RPM shocks
Cheers. Pat
Sparky84
Quote from: camo on May 21, 2017, 09:12:21 AM
How's the Nitron performing Camo?
Yes a bit of greasing wouldn't go astray.
Quote from: Pat Conlon on May 21, 2017, 10:22:13 AM
That would be nice to have Pat.
So no other parts required unless I find worn bushings, that's good to know
Just need to pick a shock!
Cheers Alan
1979 Kawasaki Z1300
balky1
Quote from: Sparky84 on May 22, 2017, 07:16:33 AM
Hopefully you will find all the bushings in working order, otherwise you will need to swap to 86/87 linkage or have the bushings made since I think none of them is available from Yamaha anymore.
Cheers Alan
FJ 1100, 1985, sold
FJR 1300, 2009
