fairing repair
Started by yaman, April 22, 2017, 06:42:39 AM
yaman
mine needed (need) it in alot of places
its a tough thing to deal with, i failed with the plastic welder- lack of skill i imagine
i found "plasti-fix" and it seems to be a great product, i will see when parts are installed and stressed on the road
but for now, i am very happy with its strength and the fact that it sands the same as the existing plastics and blends without the need for filler
comes with a moulding block that helps copy broken tabs pretty good
yaman
yaman
yaman
dremal, file and sandpaper
yaman
worked great on the air scoops and seems to have bonded to the dash also
yaman
i also found that my upper was held together by the paint around the right mirror mount with cracks spidering from the mounting holes
decided to make the commitment
the fairing is frightening to look at at the moment-lots of repair and is going to require me to repaint the black section of the upper
man, what a bit of cleanup can lead to
and what, about a month to go before Ouray
i think its doable
Looks the same as plastex. At the plastex online store you can get refills, large kits. More of the molding bars. I've been praising it for years works great. Way easier than welding. No chance of melting more than you want to (I also have a plastic welder). No filler needed. Works great.
Thanks for the write-up.
Oh yeah plastex comes with a how to video. Which are available on the website too.
Great post! This is a very good example showing the repair process.
yaman
Quote from: giantkiller on April 22, 2017, 09:21:42 AM
dang, went to the website and it looks like its the same product with a different name
the website has a s#%$load of good info, thanks
yaman
Quote from: FJmonkey on April 22, 2017, 12:28:18 PM
thanks Monkey,
i hope the product is a permanent fix as i took the plunge on a conspicuous location of the upper, there will be no hiding the fail if it gives out
If you repair the cracks from the back side. All you see from the front is a hairline crack.
And you can reinforce it on the back with fiberglass cloth. Very strong then. You can get really fine fiberglass cloth from hobby shop.
Quote from: giantkiller on April 28, 2017, 08:24:36 AM
Looked closer at the first pics. Looks like you already used fiberglass in some of the repairs.
The fine stuff from the hobby shop is easy to finish.
yaman
thanks killer
i hear you and wish i could have felt good about stopping there, that's where i started but the damage was so extensive that i decided to go at it from both sides in hopes of not having to revisit again
that's good advice on the fine fiberglass cloth thank you, I had not heard of it until you replied here, i am gonna have to check the bay- nearest hobby shop is a ways away, unfortunately
roverfj1200
I have found Q-Bond useful in repairing fairings..
1988 FJ1200
Richard.
