blue smoke on starting
Started by scotiafj, April 17, 2017, 06:41:33 AM
scotiafj
Hmm.. after giving my fj12 an oil change with bike specific oil..silkolene 10/40 ive been gettin blue smoke on starting after its been sitting over nite which clears after about minute or so ..never noticed it doing it with castrol gtx 10/40 car oil or 20/50 car oil ..its not drinking it jus blue smoke on starts..anything to be worried about? mileage is 48000 miles cheers :)
FJ1100mjk
Quote from: scotiafj on April 17, 2017, 06:41:33 AM
Based on your description, no. Probably valve seal(s), allowing oil to leak by when it sits for awhile. Very little consumption, unless things get worse.
Seen it before, and other than being an occasional annoyance (and potential embarrassment), not a big problem.
Iron Balls #00002175
www.ironballs.com
Quote from: scotiafj on April 17, 2017, 06:41:33 AMHmm.. after giving my fj12 an oil change with bike specific oil..silkolene 10/40 ive been gettin blue smoke on starting after its been sitting over nite which clears after about minute or so ..never noticed it doing it with castrol gtx 10/40 car oil or 20/50 car oil ..its not drinking it jus blue smoke on starts..anything to be worried about? mileage is 48000 miles cheers :)
scotiafj,
Yamaha makes a product called Ring-Free, which may be all you need there.  Dealers should have it, and Amazon, of course.
https://www.amazon.com/Yamaha-Yamalube-Ring-Additive-ACC-RNGFR-PL-12/dp/B002GU4SN2/ref=sr_1_1?s=automotive&ie=UTF8&qid=1492429775&sr=1-1&keywords=Yamaha+ring-free
Motorcycle oil is simple stuff.  Automotive oils can be rather complicated.  The FJ Owner's Manual will tell you what is needed.   :yes:
Beyond that, things can get complicated.  If you always use good air filters, you should still have a young engine there.  Some oil-and-foam air filters do not do the job, though, especially in dusty locations.
PaulG
Not wanting to add what could be another endless oil thread, but...  :pardon:
How long have you been using car oil in your FJ (or any other bike)?
Quote from: red on April 17, 2017, 07:02:46 AM
Uhhhmmmmm.... isn't it usually the other way around?  M/C oils deal with far higher stresses than most cars due the the extra forces from the clutch and gearbox.
... you should still have a young engine there.
If you've been using car oil for the most part, that might be an overstatement.  Just my opinion.
1992 FJ1200 ABS
YouTube Channel Paul G
GS Jockey
Big air cooled engine with big tolerances. 10/40 can be a bit thin for them. Used it in my first 3CV, and it got through it about 1l/1000miles. Swapped to the club recommended Morris Ring Free 20/50, and consumption dropped to around 150ml/1000 miles.
Try Silkolene Super 4 20/50 semi synthetic. It's what's in mine now, I've used it since I first got the bike in Sept 09, and never seen any blue smoke and I maybe top up around 100-150 ml between changes, which for me can be up to 6000 miles. Which is why I prefer the semi synth, it lasts longer.
Though mineral oil, the Morris Ring Free is good stuff, but the Silkolene is also easier for me to get hold of.
Unfortunately I am no longer young enough to know everything...
+1 on the valve seals. Same on my air cooled high mileage Porsche 911. 250k and untouched... yet. Just keep oil in her and ride.
