XJR1300 Alternator
Started by aviationfred, February 14, 2017, 08:32:43 AM
I am installing a XJR1300 alternator. The main reason is for aesthetics. I have always disliked the look of the OEM alternator. Too me, it looks like something that belongs on a 1950's Massey Ferguson tractor.
Looks interesting Fred.....is there any additional wattage capacity with the XJR vs OEM ?
Quote from: Pat Conlon on February 14, 2017, 09:46:32 AM
I am not sure. Maybe Randy can answer that question. These can be purchased brand new on the RPM site. http://www.rpmracingca.com/proddetail.asp?prod=Alternator
I don't think there's any more watts to be found in the FJ/XJ alternator.  When I was having starter issues a few years ago, I spoke to a guy that did custom winds for starters (24V) and also alternators.  When I asked about squeezing some more out of the FJ Alternator, he just laughed!  It's already at 100% of capacity for the case-no more, no how.
YMMV.
The alternator is installed. One thing to note. The mounting eyes on the XJR alternator are thicker than the FJ alternator mounting eyes. Longer bolts are required.
I also added a pair of auxiliary lights in preparation of my ride to the WCR. 3000 lumens each at 5000k color.
Quote from: FJmonkey on February 14, 2017, 08:29:04 PM
Damn!! Serious light Fred.
I will be trading out my 5000k HID light kit for a 5500k LED hi power kit that is 3800 lumens. This is the bulb I will be ordering.
http://www.aerostich.com/high-power-led-headlight-bulb-kit.html
Little Pink Steve
Nice mod there.......was there any weight difference between the two.
Currently ride 3CV White 1989
Currently working on a Yamaho FJ Bitsa.
The XJR1300 alternator weighs about 1 pound more than the OEM FJ1200 alternator.
I must say Fred. You have the wurst case of the dreaded moditis disease. That I have ever seen. Hopefully someone will start group sessions​ so we can help each other recover from this.
jscgdunn
Quote from: giantkiller on April 05, 2017, 08:25:04 AM
Keep it quiet from Fred.  There is an intervention planned at WCR.  The process will involve plenty of sharing and a 12 pack program.
90 FJ 1200 (Son # 2), Stock
I must say Fred. You have the worst case of the dreaded moditis disease. That I have ever seen. Hopefully someone will start group sessions so we can help each other recover from this.
I guess you've never met Pat.  I think Pat is the most severe documented case.  Fred's condition could still deteriorate(?) though, depending on how long his wallet holds out.  I guess you could say, 'depending on his will to spend'!
No, Fred has many more mods of his FJ than I have on mine...
....then again, I can only think of one 1350cc FJ (in the world) that has an uber trick 24v starting system...
Earl Svorks
  Fred,,
Do you know what the aggregate current draw from the 5 lights is @ 14 v?
   Simon
The lights are as follows.
Turn signal/running lights...White 5000k/Amber Cree Switchback LED 60 watts
Headlight...5000k HID 35 watts
Auxiliary driving lights...5000k Cree LED 120 watts/3000 Lumens
I will be able to get actual running amp draw numbers later this evening.
